Moved Washer, Dryer And Laundry Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2007, 09:52 AM   #1
Moved Washer, Dryer and Laundry Tub
I recently moved my washer, dryer and laundry tub from the first floor to the basement. I'd now like to cap off the unused water lines (there are two sets; one for the sink and one for the washer) and drainpipe. My question is should I simply do this inside the wall on the first floor or do it in the basement. Second question is: how? The pipe is PVC, not copper.
Thanks.
chaz is offline   Reply With Quote
Old 11-03-2007, 10:40 AM   #2
ICF Construction
If the basement is open and accessable to the supply lines I would do it there. You can purchase permanent caps at local home centers and plumbing wholesalers to complete this work, caps are generally the same material as the pipe.
Chris
Chris Johnson is offline   Reply With Quote
Old 11-03-2007, 11:09 AM   #3
thanks
so let me know if i've got it. i'll shut off the water supply in the basement, allowing the water to drain from the lines, cut the line in the basement (hacksaw or something like that), cap the top--little bit of pipe cement around the cap, then cut the pipes back inside of the wall on the first floor, couple drywall patches and i'm done. missing anything here?
Old 11-03-2007, 01:33 PM   #4
ICF Construction
yep, if it's PVC you will need to use a primer first, then the pipe glue, affix the cap let it set for a while before turning the water back on. Nothing worse then trying to fix a leak in a flooded basement.
Chris
Old 11-03-2007, 02:35 PM   #5
Long-Time DIYer
Mike Swearingen's Avatar
You may have PVC for cold water lines and drain lines only.
Hot water requires CPVC. Look on the pipe and at the pipe to tell the difference.
You will need CPVC caps and CPVC glue on CPVC lines.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Underfloor Dryer Duct kashimama Appliances 6 09-03-2007 03:27 AM
Upstairs Laundry Room Install Matt Burks Remodeling 3 08-21-2007 11:12 PM
Remodeling Laundry Room/Closet on 2nd floor mwehnes Building & Construction 6 02-09-2007 09:41 PM
Gas dryer pipe jscholl411 Plumbing 1 06-07-2006 08:21 AM
