Moved Sink And Now Won't Drain. Venting Issue? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-03-2012, 01:18 PM   #1
Moved Sink and now won't drain. Venting Issue?
I moved my sink to the corner and now water slowly collects and then drains very slowly. I thought it was the disposer, but that works fine. So, I dismantled EVERY PVC pipe to the basement and kept testing each part by adding on, letting the faucet run, and the water empty into a trash can. Each time it worked as a pipe section was added. It stopped working once I put on the last pipe in and had a closed system. BINGO - the problem is a venting one, right? So, I added an automatic air vent, but that did not solve the problem. The water still slowly collects until it backs up in the sink, then slowly drains.
Attached is a schematic. I know I have a lot of 90 deg angles to the sewer, but the AAV and continuous waste vent should handle these, right?
Pharmtoxboy is offline   Reply With Quote
Old 09-03-2012, 04:00 PM   #2
Rewards Points: 1,560
Whether to your local code or not, the level of the AAV needs to be higher than the level of the sink drain I believe.
bob22 is offline   Reply With Quote
Old 09-03-2012, 06:28 PM   #3
try pulling the rubber insert out of the top of the drain if you can. mine does that sometimes and i didn't move the sink just replaced the disposal. the rubber on top of the old one was a lot looser from age. if yours doesn't remove just use your fingers to hold it open while running the water.
Old 09-03-2012, 06:42 PM   #4
Bombastic Idiot
notmrjohn's Avatar
So its one line from sink to end, nothing else connects to and drains thru same pipe? Clog is past your "last pipe" but before anything else connects to "To main sewer connection."
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Tags
slow sink vent aav
