Move The Toilet Or Leave It? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2012, 12:29 AM   #1
Move the toilet or leave it?
Im new to the forum an have a question for the guys that know what im getting myself into:
Im looking to move the Toilet over about 3.5 feet in my slab foundation house. The house was built in 1962 and has the original 3" cast iron drains for the toilet sinks ect... I dont want to run a pipe from the old toilet location to the new one because I dont feel the line will have enough drop between the new toilet location and the old and I feel I will run into stopped up lines in the future.
I was planning on running a new pipe from the new toilet location to the main line which is in the ground probably a few feet below the foundation. I am in question to what the the old cast iron main line condition is going to be whether it will be in good enough shape to be cut and spliced into with rubber boots and pvc or if it will be so bridle that it starts to fall apart on me.
Or maby its possible to run it back to the original location under the foundation the only prob is, is that the original location only drops about a foot down from the top of the foundation before it turns and goes to the main line.
The idea of this is to get a two sink vanity in vs. a single.
I know its alot of stuff in there but your 2 cents and experiences is appreciated.
Thanks in advance,
Jon
rockys is offline   Reply With Quote
Old 02-02-2012, 12:36 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
I think that you do not and can not know what your drop might be until you open the slab.
Start with a trench from old toilet location to the new location.
Andy.
AndyGump is offline   Reply With Quote
Old 02-02-2012, 01:00 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 348
Rockys, when you look down the toilet flange, can you tell how long the piece of pipe is between the flange fitting and the 90?
As far as the condition of the pipe, its really hard to say. but its probably in o.k. shape
Old 02-02-2012, 01:21 AM   #4
It drops straight down about 12" then 90s
Old 02-02-2012, 02:32 AM   #5
At work if we come across a half-rotted CI waste line, we cut into it with a metal grinder. Chances are thats what you will be doing anyway unless you have a chain cutter.
Chop around the existing flange and chop the cement following the elbow in the direction of the branch line on it's way to the main. It will be easier to first cut this branch line back then 45 it towards the new flange location then to cut a new wye into the main. Sounds like pitch wont be a problem if your moving it 3 feet. Hopefully this toilet branch is already vented somehow. If you need to cut the branch back further then the vent line, just re-connect it in pvc.
Your new flange needs to be 12" off of the new, finished bathroom wall that the toilet tank will rest against. If your facing the wall with 1/2' rock, rough your new flange 12 1/2" off the rough framing. Likewise if your doing an inch of backer board thin set and tile, rough the flange 13" off of the rough framing of the tank wall.
PlumbDumb is offline   Reply With Quote
Old 02-02-2012, 08:23 PM   #6
Thank you sir you have just given me the confidence to make this thing happen your the man!Thanks again
Old 02-03-2012, 01:30 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 812
Not trying to hijack....but is that 12" to the center of the flange or 12" to the edge?
Old 02-03-2012, 09:33 AM   #8
Plumber
Rewards Points: 348
From center of flange- always measure from center
Toilet Problems akim1220 Plumbing 6 02-25-2014 06:59 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 12:04 PM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 11:12 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
