#1 |
Move Diverter Valve from Handle to Spout
My current single handle tub/shower faucet has the diverter located below the handle, through the back plate.
The new trim kit I'd like to buy has the diverter in the spout. Can I set the diverter position to the tub, remove the existing knob and plug the hole with a brass threaded plug? There must be a way to get around this without replacing the whole valve assembly. Thanks in advance. Deb |
#2 | |
Master General ReEngineer
Move Diverter Valve from Handle to SpoutQuote:
All the parts, 'n pieces must Match each other... |
#3 |
Special User
What brand of valve do you have now -- Delta, Moen, Grohe, Kohler etc? Can you post a picture of it?
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk. |
| Display Modes | |
| How to diagnose gas valve problems | Nestor_Kelebay | How To Guides | 27 | 03-07-2013 03:17 AM |
| pressure relief valve is leaking on boiler | wlmpdiycr | HVAC | 65 | 10-26-2011 06:00 PM |
| Tub, Separating valve and spout | bigmatt | Plumbing | 0 | 02-05-2010 04:23 PM |
| Resource for understanding gas valve? | darsunt | HVAC | 19 | 02-04-2009 12:08 AM |
| Tub spout diverter problem | Chaosdragon13 | Plumbing | 2 | 05-28-2008 01:23 PM |
