Mounting Utility Faucet On Unfinished Basement Wall Connected To Pex - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2013, 07:52 AM   #1
Rewards Points: 282
Mounting utility faucet on unfinished basement wall connected to pex
Replacing all water lines in 87 year old house with pex. Currently have very old brass faucet in unfinished basement over mop sink. The faucet is not really affixed to the basement wall - just sort of hung from copper lines from above. I want to replace it with something like the Central Brass model 470 faucet but I'm not certain how to mount it to the unfinished basement wall connected with pex. I'm open to any ideas - thought about purring in a couple of 2x4 as studs to create a faux wall cavity to mount a normal wall mount utility faucet with pex connected from the rear. But the ideal would be a faucet affixed to basement wall or plywood with pex lines connected from the top.
Ay ideas?
dgfit is offline   Reply With Quote
Old 08-25-2013, 07:56 AM   #2
PoleCat's Avatar
Rewards Points: 1,652
I would use stand off rings.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 08-25-2013, 08:04 AM   #3
Rewards Points: 282
Thanks - I'm googling this but not finding much in relation to plumbing - any references would be much appreciated.
Old 08-25-2013, 08:11 AM   #4
Rewards Points: 14,026
No way to mount a faucet to the sink it's self?
Another way would be to use 2, Pex drop leg elbows mounted to a 2 X 4, 2, 1/2 nipples and two ball valves.
If you want the hot and cold connected you could use one of these.
http://www.bing.com/images/search?q=...ectedIndex=417
Old 08-25-2013, 08:11 AM   #5
Rewards Points: 282
Maybe this is it - will research this
http://www.grainger.com/Grainger/rou...&sst=All&xi=xi
Old 08-25-2013, 08:15 AM   #6
Rewards Points: 282
The mop sink is not about a foot tall or so. I thought about the separate feeds with drop ear elbows but really would like to keep a regular faucet - one reason is to not have hot water splattering on hands and legs.
Old 08-25-2013, 08:28 AM   #7
PoleCat's Avatar
This is what I was thinking of. Round flange fixed to wall, 3/8 nipple of desired length, topped off with on of these clamps to hold your fixture.
https://www.grainger.com/Grainger/pi...071&sst=subset
Old 08-25-2013, 08:31 AM   #8
Rewards Points: 282
Ahh yeah I like that. Thank you!!!
Old 08-25-2013, 09:01 AM   #9
Rewards Points: 282
Thanks again - that led me to find this faucet which is perfect
Old 08-25-2013, 11:22 AM   #10
Rewards Points: 2,040
http://www.homedepot.com/p/t/1000981...a#.Uhou7z_iNco
Use Tapcons through the offset mount on the faucet.
Mounting 60" LCD to thin concrete wall flatblackstrat Concrete, Stone & Masonry 7 02-18-2013 07:21 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Framing basement exterior walls gheffron Building & Construction 7 06-08-2012 01:00 AM
Load bearing basement wall? hyunelan2 Building & Construction 9 04-23-2012 11:36 PM
Properly supporting a basement wall under furnace ducting reblace Building & Construction 7 04-01-2012 08:26 PM
