Mounting Of HWH Expansion Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2011, 12:42 PM   #1
Mounting of HWH expansion tank
Where do I actually mount and support an expansion tank? My horizontal 3/4" supply pipes are up in the I beams and then the cold supply drops down to the ball valve to the cold water in.
I know the tank has to go after the valve but I don't want it installed horizontally (and unsupported) so do I remove the valve and the supply line, then T off the 3/4" then install a new valve then the tank attached somehow (how?) to the I-beam then to the new supply then into the HWH?
Mounting of HWH expansion tank-tank1.jpg   Mounting of HWH expansion tank-tank2.jpg   Mounting of HWH expansion tank-tank3.jpg
steve0617 is offline   Reply With Quote
Old 01-16-2011, 09:06 PM   #2
Rewards Points: 1,548
Put a tee just under the shutoff valve for the water heater. Add a pipe to connect to the expansion tank that will be upright and just above the water heater with the pipe connection underneath. Any means, even ropes attached to the pipe it is screwed on and up to the joists above, can support the expansion tank.
Suggest not obstructing the water heater anode which is a long rod that unscrew and lifts out of the top of the heater and that needs headroom to remove, inspect, and replace when worn out.
Old 01-16-2011, 09:13 PM   #3
Got it. Thanks a ton.
Old 01-17-2011, 12:37 PM   #4
Homerepairguy's Avatar
Rewards Points: 998
Steve0617,
From your pictures, it's hard to tell whether you have a heat trap check valve in the hot water out line from the heater. If you don't have a heat trap check valve, maybe consider installing a "S" type heat trap to prevent the hot water from losing heat via convection up the output pipe.
Not related to your expansion tank to be installed in your cold water input line but may be something else to consider in addition to leaving room for the anode rod replacement, when you route your expansion tank line.
HRG
Homerepairguy is offline   Reply With Quote
Old 01-17-2011, 12:44 PM   #5
Originally Posted by Homerepairguy View Post
Steve0617,
HRG
No heat trap at all. When the heater's going, the cold line gets warm too. Bleh. Will fix that too.
Is a Hot Water Expansion Tank required Needagameplan Plumbing 9 04-27-2010 03:09 PM
Installing a new boiler expansion tank CoachDad HVAC 0 01-06-2010 01:12 PM
Pressure relief leaking and expansion tank full themow HVAC 1 11-25-2009 04:49 PM
Hydronic expansion tank mounting Joe F HVAC 3 09-28-2009 04:17 PM
Installing new expansion tank ted schumm HVAC 2 07-19-2009 09:49 PM
