Old 08-20-2008, 08:22 PM   #1
Mount an undercounter sink on top?
We are planning to do our countertops in either porclean tile or 12" square granite pieces. Either would make putting in a undercounter sink difficult, but we prefer the way the faucets mount through the counter on sinks with different sized bowls, rather than through the apron of a drop in unit. Was wondering if it is possible to use a undercounter sink mounted from the top in some manner. These appear to have an inch or so of rim. It would probably entail epoxying mounting hardware to the sink below the countertop.
nicksteel is offline   Reply With Quote
Old 08-20-2008, 09:21 PM   #2
Moderator
Termite's Avatar
You want to mount and undermount sink as a conventional above-counter mount sink? The reason for this is because you don't want faucet holes in the sink and would instead prefer to install the faucet through holes in the counter? Just making sure I understand the question.
You probably need to take a look at some undermount sinks. Most are not going to work very well for your application. They have rims that are intended to contact the underside of the counter, as well as mounting holes in some cases, that make them aesthetically unappealing. Many won't have a flat spot to rest on the top of the counter anyhow.
You probably need to abandon the idea of using an undermount in a top mount application.
There are a number of kitchen and bath sinks out there that don't have faucet holes, if that is in fact what you're after.
Old 08-29-2008, 05:10 PM   #3
I work for a company that manufactures and distributes only undermount sinks. We get this question a lot. Our undermount stainless steel kitchen sinks do not have the installation holes already drilled and technically can be used in a top-mount fashion. We do not recommend this though because the flange (or rim) is flat which leaves a somewhat sharp edge and makes it hard to properly seal.
I hope that you have solved your problem by now but if you are still researching, please feel free to check out or website at www.mrdirectint.com
KellyW is offline   Reply With Quote
Old 08-31-2008, 08:18 PM   #4
The one I have also has no holes and has flat flange. Still looking into mounting it on granite tile counter top.
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 09:43 AM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 07:42 PM
Installed Granite w/ Top Mount Sink JackOfAllTrades Remodeling 5 02-02-2008 08:30 AM
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 01:25 PM
