Mortar Under My Shower Pan... - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2012, 02:13 PM   #1
Rewards Points: 242
mortar under my shower pan...
I'm installing an American Standard shower pan on an Advantech sub-floor. I'm wanting to install it using a mortar base...as I've been advised...to use the five pile method...or glop. That's on glop in each corner, then a glop in the middle. This method was suggested because then the mortar would have room to spread out. Sound good?
Before I start, I thought that I'd check in here and get some advice...like:
1. What's the best or acceptable mortar.
2. Tips on the installation.
3. Some things not to do.
4. Sub-floor prep.
And, any other helpful comments that the experts here think would help.
I'm not wanting this to go backwards...know what I mean.
I appreciate any help that I can get...
Ed911 is offline   Reply With Quote
Old 11-04-2012, 08:46 AM   #2
DIY staff
Rewards Points: 7,174
I use masons mortar----fairly dry mix-----I do use the blob method , but I make more little piles than the 5 you mentioned----much depends on the design of the pan---you want the entire base supported---so figure out the best method to get that done---
Press the pan firmly into the mud---add roofing nails above the flange to keep the pan down into the mud--
Avoid standing on the pan and flexing the pan----that will compress the mud base to much and leave you with a 'hollow' when the pan springs back----
Old 11-04-2012, 09:00 AM   #3
Rewards Points: 13,274
I also would lay tar paper down on the subflooring before the morter.
Old 11-04-2012, 01:02 PM   #4
Rewards Points: 242
Thanks Mike...good advice. You too Joe. I actually hadn't heard of anyone suggesting tar paper. I'd hate to buy a whole roll for one little piece, but if it's worth it, I will.
Ed
Old 11-04-2012, 01:35 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 452
Ed
use plastic such as a trash bag
The Following User Says Thank You to TheEplumber For This Useful Post:
joecaption (11-04-2012)
Old 11-04-2012, 04:29 PM   #6
Rewards Points: 630
i use plastic and if i need to get the job done and can not wait for mortar i use speed set go to lunch for an hour then can stand in pan for walls
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
Old 11-05-2012, 07:24 AM   #7
Rewards Points: 3,130
Advantech has a 50-year moisture damage warranty. I wouldn't bother with any tar paper or plastic.
Old 11-05-2012, 02:04 PM   #8
Rewards Points: 242
I called Advantech customer service, and you are correct according to the Advantech engineers.
I was told that since it's a one time application, that it was okay to apply the mortar directly to the Advantech and then install my shower pan...under the condition that the Advantech wouldn't be staying wet, or wet repeatedly.
Thanks, Ed
Old 11-05-2012, 02:46 PM   #9
Rewards Points: 242
How much mortar should I buy? My shower pan is 60" X 31.25." The pan is about an inch off of the floor in the center.
Ed
Old 11-07-2012, 08:46 AM   #10
DIY staff
2 bags----maybe three-----depends on the size of the bag----
Ed911 (11-08-2012)
Mortar shower pan over concrete Bad4you77 Kitchen & Bath Remodeling 4 03-09-2012 08:11 AM
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 09:45 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
