More Space Trouble On Bathroom Waste Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-09-2011, 09:06 PM   #1
Rewards Points: 137
More space trouble on bathroom waste pipe
Very tight where I'm working...didn't plan on it. Wondering if this pipe is allowed to be used for waste water. Rotate the picture 90 degrees clockwise and I'd like to have the waste go down and meet up with other on the right side from the top. Or could I lay it all on it's side (slightly up) and then go up with a 90?
I have a long sweep that is just too long.
Hope this makes sense.
wease is offline   Reply With Quote
Old 02-09-2011, 11:19 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 834
Do you want to rotate the fitting while its standing up or do you want lay it on its back? And then you want to do what with it? I'm confused How about a drawing. The only way waste water can enter that tee is as shown- through the top or the side. You can not lay a tee on its side or back when used for drainage
Old 02-10-2011, 07:23 AM   #3
Rewards Points: 137
What I need to do is join up two 3" waste lines into one 3". One will be coming horizontally and the other will be coming from the top (or I could do side). They will come together and exit horizontally. I imagine I will need to use the long sweep?
Old 02-10-2011, 08:39 AM   #4
Plumber
Rewards Points: 834
You will need to use a wye or the combo you have pictured.
How would you support pipe in existing joist space? wease Plumbing 18 02-06-2011 05:20 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
water running down waste pipe rav927 Plumbing 5 07-04-2009 09:24 PM
Waste Pipe Replacement Handymom2008 Plumbing 5 11-24-2008 10:49 AM
Leak where waste pipe exits the house miscione Building & Construction 2 09-26-2008 02:17 PM
