More Drain Size Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-29-2010, 08:31 PM   #76
Plumber
TheEplumber's Avatar
Rewards Points: 568
Originally Posted by Proby View Post
It could, but the plan is to install a shower in there and since the leaking issue involves ripping the walls and the tub out from the shower area, it makes sense to do it this way.
As for inspectors, we have mutual agreements. The day my 1/2" small temporary drain hurts someone is the same day I'll feel bad.
since your choosing this route- may I suggest bushing the shower strainer or tailpiece to 11/2" and using a 11/2" trap.
The best thing to do is cut in a 2" wye for a new shower branch and pipe it completly in 2"
But if you choose to reduce your pipe size, try to do it in the verticle. Soap and hair, etc. will have less chance of clogging your line.
Old 07-29-2010, 08:47 PM   #77
Plumber
Rewards Points: 568
@ DM, I want to ask a couple questions for clarity-
why do you have a 90 on your tub trap?
why the 2 90's at the lavs, why not one riser with a fixture cross simular to your toilets? And how are those 2 90's connected to the horizontal line?
Old 07-30-2010, 06:35 AM   #78
the Musigician
DangerMouse's Avatar
The 90 on the tub was a booboo, .....kinda dumb of me, since the drain goes straight down through the floor, huh? lol
Nothing is glued, I'm just getting the feel of what pieces go where.
The 2 90s are on an incorrect tee as well, not sure WHAT this thing is....2"X2"smoothX2"threaded???
DM
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 07:31 AM
Old Clawfoot Tub Drain missing nut - can't find size! wombosi Plumbing 0 01-26-2009 04:48 PM
Drain configuration, which should I use? moneymgmt Plumbing 3 01-10-2009 09:10 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
drain pipe size for kitchen sink, garbage disposal, and dishwasher ? amakarevic Plumbing 5 08-05-2007 12:23 AM
