More Drain Size Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-28-2010, 07:19 AM   #31
the Musigician
DangerMouse's Avatar
One more quick question before I continue. I have 1" smooth pvc sch40 couplers, is there a DWV coupler required, or are these ok?
Thanks!
DM
Old 07-28-2010, 07:35 AM   #32
the Musigician
YAY! It finally let me upload.
DM
Old 07-28-2010, 07:38 AM   #33
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
DM,
Not sure about the couplings, maybe a real plumber will chime in. There are DWX couplers, the most obvious difference is the depth of the glue joint is only 1/2" vs the Shcd 40 where the joint is 1" deep. An inspector would certainly see them easily and might make him dig a little harder. Personally since DWV couplings on cost 50 cents each, I would use them.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 07-28-2010, 07:43 AM   #34
the Musigician
Cool, I have the smooth ones in a bag to go back to the store for swapping out.
Thanks!
DM
Old 07-28-2010, 07:43 AM   #35
A "Handy Husband"
rjniles's Avatar
DM,
Hate to say it but in you last pix, I think you have created a S trap. You need more length on the trap arm. I believe it is twice the dimension of the pipe size minimum. 3 " in your case. If you use a regular sanitary tee instead of that long sweep, I think you will meet the requirement.
Old 07-28-2010, 08:18 AM   #36
Electrician
Proby's Avatar
To add to this topic a little bit, when plumbing the drain for a shower stall with no future access from underneath, should it be done in all glued fittings? Or should any pieces have those threaded fittings (not sure of the name)?
I've seen some pictures here and many times not all the fittings are glued, one or two of them have that threaded piece so it could be removed. I'm just wondering the best course of action?
Proby is offline   Reply With Quote
Old 07-28-2010, 08:22 AM   #37
the Musigician
No reason to "hate to say it"! I'm truly grateful for all the input I'm getting to have this laid out correctly for the 'pre-rough-in' inspection. Po)
I added the longer trap arm, and will get the shorter sanitary tees and other swapped out parts today.
This pic should be pretty close?
DM
Old 07-28-2010, 08:24 AM   #38
the Musigician
Good question. I'll be working on the bathtub drain next.
DM
Old 07-28-2010, 08:28 AM   #39
the Musigician
Now, earlier, it was suggested I add a cleanout to the P-trap. Doesn't it unscrewing easily qualify it as a cleanout as well?
DM
Old 07-28-2010, 08:29 AM   #40
A "Handy Husband"
rjniles's Avatar
Shower drain should be all glued fittings, no slip joints. BTW shower drains must be 2"
Old 07-28-2010, 08:30 AM   #41
Electrician
Proby's Avatar
Is that what the threaded fittings are called, slip joints? Is it code to use all glued fittings or just good practice?
Thanks.
Old 07-28-2010, 08:31 AM   #42
A "Handy Husband"
rjniles's Avatar
Since you are using a slip joint P trap there is no requirement for a clean out.
Old 07-28-2010, 08:41 AM   #43
the Musigician
Didn't think so.... Here are 2 old pieces that should be showing what I need to buy now. Do they make a DWV 1" top to 2" bottom sanitary tee for the kitchen sink? Or should I just go 2" for the vent as well? If so... what the heck do I do with the 40' of 1" pipe I already have??? LOL
The cleanout piece will be 2" for under the tub.
DM
Old 07-28-2010, 08:57 AM   #44
Plumber
TheEplumber's Avatar
Rewards Points: 828
@ Danger Mouse, I'm still learning the post features here so forgive me if the attachment doesn't work, but it shows the best way to plumb your kitchen sink. You'll find simular pictures on the site you posted.
I hate seeing all those extra fittings under your sink when I don't think they're needed. Maybe I'm not seeing your layout right.
And I have always been required to install clean outs on kit sinks. You can get a 2" C.O. tee and reduce the top of it or any other fitting with a 2x11/2 bushing
@ Proby, unions, slip joints, and compression fittings must be readily accessible.
Old 07-28-2010, 09:39 AM   #45
the Musigician
YAY! PICTURES! lol OK, .... yes, this helps a lot.
I'll have to assume they make a DWV sanitary tee that has 1" on top and 2" on the bottom? Also..... any problem running the 2 45 elbows on the vent to have it tuck into the wall? (earlier post) .....with the correct DWV fittings, of course.
Thanks so much to all helping!
DM
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 07:31 AM
Old Clawfoot Tub Drain missing nut - can't find size! wombosi Plumbing 0 01-26-2009 04:48 PM
Drain configuration, which should I use? moneymgmt Plumbing 3 01-10-2009 09:10 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
drain pipe size for kitchen sink, garbage disposal, and dishwasher ? amakarevic Plumbing 5 08-05-2007 12:23 AM
