More Basement Rough In Help Needed - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2012, 11:51 AM   #1
Just like the 3 other posts today on this, I need a little help figuring out my rough in setup. My main issue is what appears to be the Shower/Tub pipe is kinda in the middle of nowhere. I know I can move it but I would like to avoid that if possible.
I have attached a .pdf drawing and I have the pipes labeled in parenthesis with what I believe they are. There is also a 'mystery pipe' down towards the Sump so any help on what that is would be nice as well.
Thanks for any assistance in advance!
swans13 is offline   Reply With Quote
Old 01-24-2012, 01:17 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by swans13 View Post
...I need a little help figuring out my rough in setup.
Do you have access to the original builder and/or plumber.
Also there should be "as built" drawings (somewhere)
Old 01-24-2012, 01:33 PM   #3
Rewards Points: 156
Your 'mystery pipe' is most likely the cleanout to your main line.
Branden is offline   Reply With Quote
Old 01-24-2012, 01:39 PM   #4
I bought the house as a foreclosure and don't have the drawings. I can go to the county and get them which I plan to do but was curious what feedback this forum could provide.
Old 01-24-2012, 02:02 PM   #5
Rewards Points: 2,238
The drain for the proposed shower could be so that the shower was a
"side-load" into the proposed bathroom.
It does look like it's far enough away from the toilet -
(not far enough for us - but: that's our call!)
(It would probably work, though.)
The capped, 4" pipe could be something for "Raydon", abatement - or a floor drain - that, they simply, didn't finish.
Maybe, a "clean-out"?!
(That someone didn't finish!)
rossfingal
("didn't finish"? - sometimes it's hard to get people to "come-back"!)
rossfingal is offline   Reply With Quote
Old 01-24-2012, 04:57 PM   #6
@rossfingal
I am not sure I follow the 'side-load' shower idea you mentioned. Can you elaborate?
Part of my problem is that if I use everything where it is today, I will end up with a leftover space below the bathroom that is not large enough for a bedroom (ends up being ~ 9' 6" x 11' 4"). If I move the toilet so it is the standard 18" from the vanity, I can make a comfortable shower and a bedroom that is 10'4" x 11'4".
Old 01-24-2012, 06:12 PM   #7
9' - 6" X 11' - 4" is large enough for a bedroom.
(In some places)
If you're concerned about space requirements move the toilet and
the shower-drain.
rossfingal
Is this on a concrete floor or framing (wood)?
Old 01-24-2012, 06:39 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 684
If the sump is for ground water and not sewage then I suspect the 4" to be a back water valve. Is this where your drain exits the house? Whats under the cap?
Old 01-24-2012, 10:54 PM   #9
I think I have enough info to go on. I was trying to avoid moving the toilet rough in but at this point, to get the setup I want with room size, I will pretty much need too.
Thanks for everyone's input.
Old 01-25-2012, 03:06 PM   #10
Rewards Points: 12
Would you be able to take and upload a picture? I'm trying to compare that with my rough in layout for the basement. Thanks
charlie902 is offline   Reply With Quote
Old 01-25-2012, 03:51 PM   #11
Sure. I will post it tonight.
Old 01-27-2012, 09:04 PM   #12
Rewards Points: 12
Dont forget the pics when you have a chance. Thanks
Old 01-27-2012, 09:17 PM   #13
Does this help?
The Following User Says Thank You to swans13 For This Useful Post:
charlie902 (01-27-2012)
Old 01-27-2012, 09:58 PM   #14
Rewards Points: 12
Thanks. Good luck with your project. Post pictures when done, please
Tags
basement , colorado , plumbing , rough in
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Basement Insulation: Drylok first? Advice needed whiteblur Building & Construction 2 09-27-2010 10:58 PM
Basement bath rough in question rdtour Plumbing 2 12-29-2009 10:32 PM
Basement toilet rough in epeterson777 Plumbing 7 01-27-2009 12:57 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
