Mono Flow Tee - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2011, 10:38 AM   #1
mono flow tee
I have a separate zone in my attic that was installed for future use on my hydronic system. Two 3/4" copper pipes, 1 send & 1 return connected together.
The future is now and I have opted for a Turbonics recessed heater (basically a toe kick in a cabinet). I have a couple of questions
Do I still need a mono flow tee on the return even though I have separate pipes going in and out? If I don't can I add an additional unit further down stream later without a mono flow tee on the return ?
Chestersthing is offline   Reply With Quote
Old 12-13-2011, 02:32 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Hydronics or hydroponics? Whatcha' doin' up there?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-14-2011, 08:12 PM   #3
I'm breading wallaby's .... Do I need the tee or not?
I thought I understood plumbing, private well flow rate question ChrisDIY Plumbing 22 07-25-2011 10:14 AM
Second Floor Vent Has No Air Flow somewhatsketchy HVAC 7 08-16-2010 12:32 PM
Moving HVAC ducts/registers & reverse flow ?'s cbrc5eric HVAC 3 06-09-2010 05:05 AM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
very low shower head flow rickard681 Plumbing 7 10-08-2008 06:43 AM
