Moldy Smell From Kitchen Sink/hole Not Fully Open - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2012, 10:47 AM   #1
moldy smell from kitchen sink/hole not fully open
After looking for the smell from my kitchen sink I looked down the hole in the lefthand side of sink (side without garbage disposal) and I can see that the white pipe is not a complete hole. Looks like the hole is only half cut out. Ive put clorox down the drain and the smell comes back the next day. I could see black spots that looked like mold on the white plastic that is not cut out of the drain.
Furrball is offline   Reply With Quote
Old 02-27-2012, 10:54 AM   #2
Rewards Points: 14,014
WIth out a picture it impossile to see what your talking about.
Old 02-27-2012, 11:01 AM   #3
Sorry, I have tried but no way to take picture. While looking down drain hole...I can see only half the white pipe is open. Looks like someone cut a half circle in pipe. Should there be a round hole?
Old 02-27-2012, 11:04 AM   #4
Also, looking in drain hole I can see dirt or something at bottom of hole. Looks like pipe is not draining and food/stains are just sitting there at bottom of pipe running across. Maybe it should be on a slant to make sure it drains?
Old 02-27-2012, 11:04 AM   #5
There should not be a hole in any drain pipe.
Without that picture were all going to be just guessing at what your even looking at.
Old 02-27-2012, 11:27 AM   #6
Sorry, I guess this wasn't such a good idea trying to do this online. I just don't know how else to explain. When you say there should not be a hole you are not getting what I'm trying to say. There has to be a hole from the sink to allow whater to go out and down the drain. What I'm trying to explain is that the hole in the sink drain looks like a white pipe coming from the right side was cut out to allow water to drain but wasn't the hole is a half circle. So when looking down drain with flashlight I see part of the white plastic pipe is covering the hole.
Thanks for you time on this but maybe I should call a plumber.
Old 02-27-2012, 12:07 PM   #7
This is what it should look like.
http://images.search.yahoo.com/image...6k&fr=slv8-w3i
There is no drilled holes allowed in the drain.
If someone did some funky DIY drilling instead of do it right there's just no way here to know what they did without seeing it. Sorry.
Old 02-27-2012, 12:25 PM   #8
Just a DIY guy
I have seen a cutaway view of a sanitary tee that has an internal directional baffle, so that water is directed downward. You probably have one of those.
But I have no idea if your smell has anything to do with that. Does your sink have a properly installed trap?
M3 Pete is offline   Reply With Quote
The Following User Says Thank You to M3 Pete For This Useful Post:
jaydevries (02-27-2012)
Old 02-27-2012, 02:04 PM   #9
if its an end outlet waste the tees used to have a baffle right above the inlet on the side. you could see it if you looked down through the strainer.
Old 02-27-2012, 02:50 PM   #10
Just a DIY guy
I didn't know the name, but that's what I meant, thanks.
I finally found a cutaway view of an end outlet tee, took way too long to find ...
http://www.nettally.com/palmk/GDplumbing.html
Old 02-27-2012, 03:37 PM   #11
Rewards Points: 1,668
Which side of the sink stinks? If disposer side, might try cleaning up the junk that can build up inside the disposer (with electricity off of course!).
Key question was is there a proper trap on the this drain line? If not, sewer gases can come up.
A pic of the plumbing under the sink would help.
bob22 is offline   Reply With Quote
Old 02-27-2012, 07:57 PM   #12
Rewards Points: 636
pete beat me to a pic of a baffled tail piece
also pull out rubber safety splash piece from garbage disposal strainer basket clean it well
http://www.insinkerator.com/service/index.shtml
also do you have any of the flex tubing "acordiane looking" under sink
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-27-2012, 08:13 PM   #13
Finally got what your talking about, a hole in the drain and a baffle are way differant things. I can see why it would be hard to discribe.
We have one and it stays pluged up all the time, how did someone think that was a good idea dumping ground up stuff from the garbage disposal into that narrow a drain?
I also see no way that's causing the smell.
Old 02-27-2012, 09:11 PM   #14
Rewards Points: 636
i have seen it as a jurisdictional code before if installing garbage disposal or dish washer to sink drain but it was years ago
Old 02-28-2012, 04:44 PM   #15
Just a DIY guy
A good way to clean out a disposal and make it smell nice is with citrus peels. Nothing like grinding up a lemon to freshen up the disposal.
those rubber splash pieces get pretty nasty underneath.
It took me over half an hour just to find that stupid cutaway drawing. I saw one cut in half on a DIY show, and figured it would be easy to find a drawing. But ...
Studor Mystery: Sewer Gas Smell StudorCrazy Plumbing 3 02-20-2010 11:49 AM
Need advice on open wall kitchen width. mike44107 Kitchen & Bath Remodeling 3 01-26-2010 12:57 PM
Open shelves in kitchen gorf General DIY Discussions 4 12-04-2008 08:42 PM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 08:36 PM
Which way should kitchen cabinets open??? ncoppola09 Carpentry 8 06-30-2007 05:39 PM
