Old 02-04-2008, 09:21 PM   #1
Moisture On Toilet Bowl Grout
I have some moisture at the bottom of the toilet bowl on the grout line. Can I assume the wax ring needs replacing?
jte1130 is offline   Reply With Quote
Old 02-04-2008, 10:18 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Yes you can assume it's the seal on the toilet, replace it as soon as you can.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 02-05-2008, 08:25 AM   #3
Thanks, I will. My plumber is coming over this weekend to do some minor repairs. I'll add it to the list.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
toilet bowl water level problem? darsunt Plumbing 3 08-26-2007 02:10 AM
Toilet bowl shims rjniles Plumbing 2 08-23-2007 06:06 PM
Toilet running inside bowl leroyme Plumbing 4 08-21-2007 08:50 PM
