| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Bamboo, Cork, & Clay Tile for Natural Home Design
by Expert Village
Okay now we’re going to talk a little bit about floorings. One flooring a lot us have in our homes that we don’t even know we have and we can utilize is a concrete slab. A concrete slab, you can strip your wall to wall carpeting and take the... Read More »
How to Prevent Driveway Potholes
by eHow.com
No matter what type of driveway you have--concrete, asphalt or gravel--you are at risk for developing potholes. Potholes are caused by water penetrating the surface of the driveway. In the case of concrete and asphalt, the water builds up under the... Read More »
How to Buy an Energy Efficient Hot Water Heater
by eHow.com
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Materials for Sewing An invisible Zipper
by Expert Village
Hi! I'm Karen for Expert Village. Here are some tools and materials you'll need to sew in your invisible zipper. You'll need an invisible zipper, of course. This looks flat on the front. You don't see any of the teeth, and it usually has a small dangle... Read More »
How to Prevent Cracks in Concrete
by eHow.com
If you are planning a concrete project, you will be dedicating your time and money to making it perfect. Whether you will be doing the job on you own or hiring a contractor, there are a few things you should think about before getting started. While it... Read More »
