Moen Single Valve Shower Handle Problem! - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-16-2011, 12:05 AM   #1
Unhappy
Moen Single Valve Shower Handle problem!
Shower would not shut off this morning. Closed the main valve for the day. Plumber arrived this evening and diagnosed broken handle coupling (Delta) on my single valve shower only unit (no tub). Charged $205, closed local check valves and left me to replace the handle myself. I thought, no problem. Checked the parts and found it's a Moen. Handle is Part # 93901, Handle coupling attachment plate is #93904 and ? sleeve ? is 93926. Only problem is there is nothing like it at the big orange box. Three hours of searching online and came up with zero also. I'm wondering where I can find these part or perhaps I can replace the handle and assembly with other compatible parts? I'm attaching pictures. Any help appreciated!
Moen Single Valve Shower Handle problem!-img_0613.jpg   Moen Single Valve Shower Handle problem!-img_0626.jpg   Moen Single Valve Shower Handle problem!-img_0628.jpg   Moen Single Valve Shower Handle problem!-img_0641.jpg
F8James is offline   Reply With Quote
Old 04-16-2011, 12:18 AM   #2
When I replaced my Moen shower valve, the kit came with all the necessary parts. Perhaps (if not too expensive) you could purchase the kit and just use the parts you need. Otherwise, you might try and order them from the manufacturer, or possibly an online plumbing parts warehouse.
PSDENGINEER is offline   Reply With Quote
The Following User Says Thank You to PSDENGINEER For This Useful Post:
F8James (04-16-2011)
Old 04-16-2011, 01:23 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 684
A quick search showed this http://moenparts.faucetdirect.com/ They may have what you need
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 04-16-2011, 04:32 AM   #4
Rewards Points: 476
Moen has a life time warrenty on it item's. Call the company and tell them that you have the part number's . They will send free of charge. good luck
del schisler is offline   Reply With Quote
The Following User Says Thank You to del schisler For This Useful Post:
Moen cartridge repacement - single handle shower sandmant Plumbing 15 08-27-2011 08:09 PM
Plumbing single handle shower zrooster99 Plumbing 5 02-26-2011 09:45 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Shower valve problem stephanieb_1001 Plumbing 1 06-24-2009 04:37 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
