Moen Single Handle Shower Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2011, 10:28 AM   #1
Moen single handle shower valve
So we bought this home, and the guest shower was stuck. heavy calcium buildup because former owners did not use any kind of softener. Anywho, replaced the cartridge on this older moen shower valve and only hot water.. this valve has only the 1200/1225 cartridge and two small stop valves on each side and that is it. The one thing I have not done is to remove the stop valve on either side. Maybe the cold is crumbed up? Anyone?
n224ap is offline   Reply With Quote
Old 09-22-2011, 11:31 PM   #2
firehawkmph's Avatar
Rewards Points: 1,922
You could try pulling the cartridge back out and turning the stops on one at a time to make sure they both flow. Obviously the hot one is, but just for comparison sake.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 09-23-2011, 09:45 AM   #3
That's what I will do. Not being a plumber I did not know what those were for at the time. Thanks.
Old 09-23-2011, 06:04 PM   #4
They are there so you can replace the cartridge without shutting off the whole house supply and without having an access panel on the other side of the wall. They should be 1/4 turn valves.
Mike Hawkins
Moen cartridge repacement - single handle shower sandmant Plumbing 15 08-27-2011 08:09 PM
Moen shower handle keeps breaking Seltzer Plumbing 5 05-09-2010 12:48 PM
Moen tub shower spiket valve leaks brucemoore Plumbing 2 07-05-2009 07:56 PM
Shower mixing valve replacement w/galvanized pipe rsaritzky Plumbing 3 05-13-2009 10:11 AM
Stuck Cartridge Moen Single handle wenceslaus Plumbing 2 04-02-2007 06:47 PM
