Moen Single Handle Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-11-2011, 10:10 PM   #1
Moen single handle shower
Hi,
i have a single handle shower that the cold water is is plugged and I need to clear it. I removed the on/off handle and screwed the leftover knob turning the water on (hot) and off but now I can't turn the water off. The place on the wall has two screws at like the 7 and 2 position. I need to first turn off the water and then I need to be able to clear the cold water line to this shower. please help
keoki5 is offline   Reply With Quote
Old 10-12-2011, 05:48 AM   #2
DIY staff
Rewards Points: 7,174
Sounds like this one has shutoffs built in---if they don't work any more ---just turn off the water to the house---pull the cartridge--clean the valve body---and install the new cartridge.
Moen single handle shower valve n224ap Plumbing 3 09-23-2011 06:04 PM
Trouble replacing 2 handle shower levers matt7125 Kitchen & Bath Remodeling 2 12-02-2009 07:55 AM
Low Water Pressure Delta Single Handle Shower Model 602 rckeagle Plumbing 2 07-24-2009 02:11 PM
Problems replacing two handle shower faucets bear creek Plumbing 3 02-04-2009 06:41 AM
Moen shower valve question tmbrink Plumbing 5 12-14-2008 10:17 PM
