Old 12-25-2009, 06:12 PM   #1
Moen single handle cart. removal?
I have a nearly new Moen L82383 tub shower faucet that is plugged up from rust and crap out of a banging of old galvanized pipe in a separate repair.
I have the face plate off and the horseshoe clip out(has NO bonnet nut) but cartridge wont pull out and I am afraid of cracking my ceramic tile if I pry against it. Everything else is plastic. Why does it pull off so hard?? Whats it take??
4just1don is offline   Reply With Quote
Old 12-25-2009, 06:32 PM   #2
Super Moderator
Moen has a tool to gently pull out a stuck cartridge.
They are about $15.00 where ever you buy the replacement cartridge.
Not using one can cause damage to the housing--or snap off the cartridge in the hole.
Good luck--MIKE--
Old 12-25-2009, 07:11 PM   #3
I pulled hard enough for it to come out,,,wow,seemed like excessive force.
Can rust and sediment be cleaned out of these strange looking cartridges or is replacement the only option?
Old 12-25-2009, 07:24 PM   #4
Super Moderator
You have nothing to lose by trying! The rubber pieces just lift off.
You may want to take a few pictures before you start--My memory isn't what it was.
Gently sand the interior of the hole and flush it out with a bit of water. Lube the hole with silicon or lithium grease if you have any.Vasoline might be o.k. for a Christmas fix.--MIKE--
Old 12-25-2009, 08:30 PM   #5
You could try to clean it out, but your best bet is to buy a replacement catridge. I replaced two in my house recently, easy and inexpensive. It's amazing how smooth the faucet feels after putting in a new cartridge.
walds11 is offline   Reply With Quote
Old 12-25-2009, 10:56 PM   #6
Super Moderator
Remember-Don pulled this apart on Christmas day. No stores open to buy a new cartridge.
Hope he got it to work---MIKE---
Old 04-01-2010, 09:45 PM   #7
Mike:
Thanks for the post - FYI I have a 3 year old house and this happened with 2 of my Moen Showers.
Both times I cleared the problem by disassembling the shower - yanking on the cartirge (and some minor banging side to side) - I didn't get the cartridge out (and no I didn't buy the tool) - but the movement was enough that when I reassembled the shower whatever was stuck in the cartridge was cleared and the shower worked good as new.
Good luck--MIKE--
Hicmin is offline   Reply With Quote
Please help, Stuck cartridge,Moen single handle tub faucet, Woodpecker Plumbing 23 08-24-2010 03:42 PM
Single Handle to Tub/Shower is Broken gte304k Plumbing 2 10-24-2009 11:37 PM
two handle shower faucet to single handle GLASSMAN1 Plumbing 2 01-31-2008 09:08 AM
Double Handle versus Single Handle kitchen faucet Lindahoney Plumbing 7 11-20-2007 10:36 AM
Stuck Cartridge Moen Single handle wenceslaus Plumbing 2 04-02-2007 07:47 PM
