Moen Shower Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-20-2010, 10:27 AM   #1
Moen shower faucet
Hi all new here and have a question. I recently had a Stand up tile shower installed and a moen faucet(not sure on model at this time). Well wife uses it last night and calls and tells me that the handle will go from off postion counter clockwise from 12 to 9 and clockwise from 12 to 6? Does this seem correct? Also instead of handle pointing down towards the ground It points up toward the ceiling?? I'm out of town so can't check anything at the moment..any info appreciated.. Thanks Nathan
Ndogg3539 is offline   Reply With Quote
Old 12-20-2010, 10:34 AM   #2
Owner
LateralConcepts's Avatar
It's most likely a posi-temp cartridge and wasn't put together properly. If it was recently installed and you're out of town, I would suggest having the plumber come back and properly adjust it. Unless your wife is comfortable doing so.
http://www.moen.com/shared/pdf/instr...ets/mt692c.pdf
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 12-20-2010, 10:49 AM   #3
Thanks! I haven't look at the file yet since my phone won't allow it, but is this something that can be done by just removing the handle and coverplate? Or is it located behind the tile and wall?? Once again thanks Nathan
Old 12-20-2010, 10:57 AM   #4
Owner
Yep, super simple. No need to open up the wall.
Lateral
(208) 818-8241
Old 12-20-2010, 11:18 AM   #5
Awesome! Thanks again!
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
My shower head leaks when tub faucet is running? Walter Sobchak Plumbing 4 05-24-2010 08:13 AM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 03:27 PM
Does not fully go from faucet to shower desimonkey Plumbing 1 04-21-2009 02:59 PM
Shower faucet replacement - PVC replacing steel? jdm1 Plumbing 2 11-29-2008 11:38 AM
