Moen Posi Temp Leaking (again) - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-11-2013, 10:27 PM   #1
Rewards Points: 99
Moen posi temp leaking (again)
Shower started dripping about 2 years ago and Moen sent me a free replacement 1222 cartridge. Problem fixed. Now 2 years later its dripping again.
Could the cartridge be faulty again? Did I do something wrong?
Can't believe this. Hope Moen will send another free replacement and hope i can find the extraction tool I had before.
kirwinjd is offline   Reply With Quote
Old 11-12-2013, 03:57 AM   #2
DIY staff
Rewards Points: 7,174
It could have been a faulty cartridge---When you changed it the last time,did you clean out the inside of the valve body ? I usually roll up some fine sand paper and lightly polish up the insides----then lube the valve body.
Old 11-12-2013, 07:05 AM   #3
Bill Kearney
Rewards Points: 1,174
Lifetime warranty is no good when you're having to replace the parts over, and over, and over. I bailed on Moen fixtures years ago after several fixtures kept failing. I don't have the time to keep replacing 'free' parts.
wkearney99 is offline   Reply With Quote
The Following 2 Users Say Thank You to wkearney99 For This Useful Post:
Benplumbing (11-12-2013), jaydevries (11-17-2013)
Old 11-12-2013, 08:09 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 684
Whats your water pressure?
Old 11-12-2013, 02:54 PM   #5
Master Plumber
Benplumbing's Avatar
Are you on city water or well water and if you're on a well are you conditioning your water properly...try to give many more details if possible. And are you sure it's actually leaking? Sometimes I have customers that get befuddled because they're shower head is dripping. Remove showerhead from shower arm and see if your indeed getting drips. If not it's probably just a mineral deposit build up in the shower head itself
Benplumbing is offline   Reply With Quote
The Following User Says Thank You to Benplumbing For This Useful Post:
Javiles (11-12-2013)
Old 11-13-2013, 12:40 PM   #6
Rewards Points: 99
City water supplied. Output about 60-70 psi.
Water in our area is considered very hard. We do have softener installed. House has 3 tubs all with Moen posi temp valves, however only the one leaking again is the one downstairs shower. Upstairs valves, never a problem.
The leak is pretty substantial. A few heavy drops per second. Bucket is full within 24 hrs. I will remove assembly and check. Can cartridge be removed and reinstalled without being damaged?
Thanks all for your time. Really appreciate it.
Old 11-13-2013, 01:02 PM   #7
Rewards Points: 286
Yes. Try removing and reinstalling, inspect o-ring, as it may have been damaged or worked out of place. Re-read post 2 by Mike. IMO, If it still leaks; cartdrige may be defective as mentioned above, try another cartdrige. It's very seldom that it's the valve housing unless you're using chisels and screwdrivers in there. No worries, Moen will send another one.
replacing 1222 cartdrige
jmon is online now   Reply With Quote
Old 11-14-2013, 12:40 AM   #8
Rewards Points: 99
[QUOTE="jmon"]
Ok. Great. Thanks a lot. Called Moen and new cartridge is on the way. Just hope that I can find the extraction tool I bought the last time I replaced it.
I'm very talented about losing the one tool I desperately need. Best way to find it? Buy another one. The first one will magically show up out of nowhere. I have a garage full of duplicate tools.
The Following User Says Thank You to kirwinjd For This Useful Post:
jmon (11-14-2013)
Old 11-14-2013, 08:55 PM   #9
Rewards Points: 582
had a problem with moen 30yrs ago....but fixed it for good...switched to delta ben sr...sorry for being blunt..
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
jaydevries (11-17-2013), TheEplumber (11-15-2013)
Old 11-16-2013, 10:45 PM   #10
Rewards Points: 99
So if I want to switch to delta, won't I have to rip out the entire moen manifold? How would I do that? The connections are copper sweated behind the pre fabed shower wall.
Old 11-17-2013, 05:05 AM   #11
DIY staff
Ben's post was just poking fun at Moen----Delta does make a fine mixer valve--
When you pull out the cartridge---clean the inside of the valve---roll up some 220 grit sand paper and remove any mineral build up---that step is needed----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (11-21-2013), jaydevries (11-17-2013)
Old 11-17-2013, 05:43 AM   #12
Bill Kearney
Yes, that is what it would take. Either now of one of next several times you have to replace the part... again.
Old 11-17-2013, 09:13 AM   #13
Rewards Points: 99
Great. Thanks a lot
Old 11-17-2013, 09:16 AM   #14
Rewards Points: 99
To cutout even a portion of the prefabricated shower wall, means replacing the entire shower. What a nightmare!!
Old 11-17-2013, 11:29 AM   #15
Bill Kearney
Or do it through the other side of the wall.
There are retrofit kits designed to be done from the front with as little disruption as possible. Not 'no disruption' as that's not possible. But whatever hole they do require is designed to be covered with an escutcheon that comes with the kit. Not as 'clean' a look as just a handle and small escutcheon, of course, but not a hideous hack either.
Yes, it's not trivial. But neither is putting up with a garbage piece of plumbing. How you fix it, or how long you tolerate a defective one, is entirely up to you.
The Following User Says Thank You to wkearney99 For This Useful Post:
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 05:00 PM
H2O pressure temp valve leaking amiso Plumbing 1 08-11-2011 11:44 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 04:43 PM
Water leaking through copper pipe. willowgirl Plumbing 10 01-17-2010 05:29 PM
Moen shower leak. Help! Pinnacle Plumbing 2 08-26-2009 07:57 PM
