Moen Kitchen Faucet Leak and Limp Handle
We recently replaced the cartridge in a five year old Moen single-handed kitchen faucet, to fix a drip. Now not only is the drip not fixed, but the handle falls down by its own weight like a quickly-wilting flower stem. I removed the cartridge, wiped off virtually all of the silicone lubricant on the cartridge piston and inside of the piston tube and re-installed it. It is a little bit better, but still limp. And the drip is as bad as before.
Any suggestions? |
There are mini washers/friction rings supplied by Moen that are placed over the stem shaft before installing the handle. This gives more friction and keeps the lever from dropping. Very common problem. I don't believe you can just buy these washers off the shelf at a local hardware. In the past Moen has shipped them to me. I do know they come in the box with the plastic lavatory or shower handles. You can purchase them for around $13 from your local hardware or plumbing store. :thumbsup:
I had problems with my Moen kitchen faucet a few weeks ago. I called them and explained the main problem I was having with it. She was going to send the part to me, free of charge. Then I explained another problem I had been having with it and she sent me a new faucet. They seem like a good company to deal with.
If you call them, they'll ask you a few questions and, at the very least, send you the part you need. Their contact info is at www.moen.com |
Thanks for the Info
Jeff and GMA2rjc,
Thanks for your ideas. I've contacted Moen, and learned, after spending $30 on a new cartridge, that they give all of it for free. In fact, the Moen plumbing advisor sent me a new cartridge, assuming the one I bought was defective, but that didn't work either. So now the focus is on the valve body (if that's the right word), the thing into which the cartidge slips...I'm soaking it in vinegar to dissolve (hopefully) any deposits which may be preventing a seal (that's the dripping part). To the untrained eye it all looks good inside, except for a little blue-green corrosion on the copper new the top of the valve body. By the way, it drips only when the hot water supply is turned on...if hot water supply is turned off and cold water supply is turned on, there is no drip (but there is limpness, a separate problem.) I will ask her about the slip rings that Jeff mentions, too. |
Moen has an awesome customer service along with lifetime warranty on all parts. Den, the washer/friction rings will definitely stop the lever from falling. Also, check inside the valve body of the faucet with a flashlight. Make sure there is nothing inside. There should be two holes/ports approx 3/8 dia. One for hot and one for cold. They are the inlets. Sometimes rubber from the old cartridge can get wedged in there. Then take a 3/4" wire fitting brush, the kind used to clean 3/4 copper fittings and run it through the valve body while turning it. I use siliconized grease on my finger and apply it inside of the valve body, just a small amount. Slowly insert the new Moen Cart, while slightly twisting it side to side until it bottoms out. The tip of the new moen cart will have a small notch on the brass portion. That is the pointer if you will. Notch to the left Hot, notch to the right cold. Hope this helps.
| All times are GMT -4. The time now is 12:12 AM. |
