Moen Faucet Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2009, 09:31 PM   #1
Moen faucet repair
I have a Moen single-handle posi-temp shower faucet that is leaking. Based on Internet research, I determined that the cartridge needs to be replaced. When I took off the handle and the escutcheon, there is a white plastic circle that is blocking my access to the retaining clip. Looking at the parts diagram on the Moen website, I think this plastic circle is the "plastic ground." I cannot remove this piece, as the hole in the shower wall is not big enough to get the piece through it. My question is if I am going to need to cut a bigger hole in the shower wall in order to take this piece off so I can get to the retaining clip and cartridge. If so, how can I do this without damaging the plastic ground, or should I just purchase a replacement beforehand and assume it will be damaged in the cutting?
I am a complete plumbing novice, so thanks in advance!
simonxx is offline   Reply With Quote
Old 04-05-2009, 08:15 AM   #2
Been a while since I worked on one of those, but check the Moen website, they should have a parts diagram that shows how it goes together.
Old 04-07-2009, 09:22 AM   #3
Thanks for the reply. I ended up making the hole in the wall just big enough to get the plaster ground out so that I could get to the retaining clip and cartridge. What a pain!
Outdoor faucet - repair or replace? ETex2 Plumbing 2 01-19-2009 03:07 PM
Moen Faucet Ques. roztom Plumbing 7 07-23-2008 01:43 PM
Faucet Repair Questions? mfleming Plumbing 3 05-07-2008 10:44 AM
Repair outdoor faucet? mx13 Plumbing 3 04-09-2007 07:08 PM
Moen 3 knob faucet repair? blue82001 Plumbing 3 06-16-2006 12:32 PM
