Moen Cartridge Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2013, 06:30 PM   #1
Moen cartridge replacement
Hi, can anyone help me? attached is an image of a moen single handle shower valve. This is probably 15 to 20 years old and is located in my fiberglass shower stall. The product model number is unknown. I'm trying to determine what kind of replacement cartridge I can purchase for this unit. Can anyone tell what model this cartridge might be. As you can see from the picture, I was trying to unscrew the screw in the center of the valve and it snapped off. Now I need to remove the cartridge now, but I don't know the model number. I've sent an email to Moen but they haven't replied. If someone can tell me what model cartridge this is and where to purchase, I'd be forever in your debt. Thanks for any assistance you can give me.
jskamm is offline   Reply With Quote
Old 02-24-2013, 06:40 PM   #2
Plumber & Gasfitter
Rewards Points: 77
Moentrol
joeplumber85 is offline   Reply With Quote
Old 02-24-2013, 07:03 PM   #3
Thanks for your quick response. Is there a specific model cartridge number as a replacement for this Moentrol valve? I read somewhere that the 1225 model will work.
Old 02-24-2013, 07:30 PM   #4
DIY staff
Rewards Points: 7,174
1225 or 1200 will work---
Old 02-24-2013, 08:14 PM   #5
Ok, great. One last question.
Do you have a model number for a cartridge pulling tool for a Moentrol valve?
Old 02-24-2013, 08:44 PM   #6
DIY staff
No on the tool,I'll see if I can find a picture---
You are in trouble with the pulling tool----it uses the screw hole in the stem---you remember,the one with the broken screw stuck in it?
Old 02-24-2013, 08:48 PM   #7
DIY staff
Old 02-24-2013, 10:24 PM   #8
Thanks oh'Mike.
Hate to be a pest. But do you have any suggestions on what I might be able to use to actually try to pull the cartridge out? Plus, If the tool screws into the stem, might I be able to pull it out with a pair of vice grips??
Also, should I spray lime away or wd40 into the valve to try to loosen the cartridge??
Again, I appreciate any other suggestions you might have.
Old 02-24-2013, 10:34 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 436
Read this thread- it might save you some heart ache
replacing shower cartridge
If you still have questions- please ask
Old 02-25-2013, 06:15 AM   #10
DIY staff
Thanks E-Plumber---that was a good thread----
Old 02-25-2013, 09:34 PM   #11
I want to thank everyone for all the assistance. I removed the old cartridge without any problem and replaced it with a new 1200 cartridge.
The Following 2 Users Say Thank You to jskamm For This Useful Post:
oh'mike (02-25-2013), TheEplumber (02-25-2013)
No flow from Delta 1700 shower valve after cartridge replacement billyjoe Plumbing 11 04-24-2016 03:42 PM
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 06:27 PM
New Moen Cartridge Is Still Leaking on Bathtub faucet rliu Plumbing 7 01-14-2013 09:49 AM
Moen cartridge replacement help on a single handle shower comptalk Plumbing 12 08-08-2012 02:13 AM
Single handle shower leaking from spout even after cartridge replacement njburb Plumbing 7 06-07-2012 08:53 AM
