Moen Cartridge Broke In Half - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-18-2014, 07:25 PM   #1
moen cartridge broke in half
When pulling out a moen cartridge it broke in half. How can the half inside the pipe/valve/brass be removed? Drill, melted or other sugestrions.
alexcobav is offline   Reply With Quote
Old 07-18-2014, 08:00 PM   #2
DIY staff
Rewards Points: 7,174
You can salvage that--however, you must be careful not to damage the valve body--if you do--you are going to have to rip out the entire valve--
You can drill out as much of the plastic as you can--grab the broken stem with needle nosed vise grips and pull---
Plummen (a member) posted his method a few weeks back---I'll see if I can find it and post a link--Mike---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
alexcobav (07-18-2014), jmon (07-18-2014)
Old 07-18-2014, 09:28 PM   #3
So far so good, at least it seems, I drilled, chiseled and pulled(With needle pliers) and it came out, cleaned a little and install new cartridge, water is flowing normally. Now I was as careful as possible, How do I know that the valve was not damage? what signs should I looked for in making sure everything is fine.
By the way thanks a lot for the tips.
The Following 2 Users Say Thank You to alexcobav For This Useful Post:
ben's plumbing (07-18-2014), jmon (07-18-2014)
Old 07-18-2014, 09:55 PM   #4
Rewards Points: 144
Nice job. Glad you were able to remove it.
Seriously doubt you caused any damage.
If you wanted to, you could have checked the valve body with a good flashlight before you put in the new cartdrige. If the sealing surface of the valve body was damaged, it would no longer seal properly with a new cartridge and would have to be replaced, imo.
But as you have already stated, you have no drips, leaks or errors, so no need to, you win!.
jmon is offline   Reply With Quote
The Following 2 Users Say Thank You to jmon For This Useful Post:
alexcobav (07-18-2014), oh'mike (07-19-2014)
No flow from Delta 1700 shower valve after cartridge replacement billyjoe Plumbing 11 04-24-2016 03:42 PM
New Moen Cartridge Is Still Leaking on Bathtub faucet rliu Plumbing 7 01-14-2013 09:49 AM
Moen cartridge replacement help on a single handle shower comptalk Plumbing 12 08-08-2012 02:13 AM
Roofing only half of the house annabruen Roofing/Siding 3 12-20-2011 09:36 AM
New Moen Cartridge leaks Firemanjl Plumbing 4 07-21-2011 11:53 AM
