Moen 1225 Valve Leaking? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-04-2009, 11:25 AM   #1
New Moen 1225 Valve already leaking?
I just replaced this valve and now I have an intermittent leak from the showerhead. I was dripping approximately once an hour, but it now it seems to be increasing in frequency. Could I have nicked one of the seals when installing it? I'm not sure what to try other then picking up another one and seeing if I have the same issue...is this a common problem?
steve65 is offline   Reply With Quote
Old 03-05-2009, 06:53 PM   #2
no opinions on this one? I don't mind replacing the valve again...I just wanted to make sure that would fix the problem.
Old 03-05-2009, 07:43 PM   #3
try this
When you replaced this you need to flush out and debris before you reinstall. Did you install a genuine moen cartridge. was it brass or plastic. Make sure it is also in the right position when you reinstall and put handle back on.
plumbbum0203 is offline   Reply With Quote
Old 03-05-2009, 08:29 PM   #4
Thanks for the reply. I honestly can't remember if it was an actual moen. I think it was another brand, but made for moen. It was all brass and I did flush it out. What it the difference between the 1200 and the 1225?
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
ball valve leaking bwall Plumbing 10 12-31-2012 07:25 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 05:32 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 08:23 PM
