Modifying Resin/acrylic Vanity Top? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2010, 12:26 AM   #1
Modifying resin/acrylic vanity top?
I've got a problem because in the area where I've placed my new vanity, none of the three sides is square.
Previously there had been a laminate top with a porcelain bowl so the top could be custom built to fit the poor framing job.
The top I bought is acrylic or some other resin and has an attached backsplash so I can't do anything with it. So, I'm of a mind to buy a larger top and cut it to fit the area I need to fill.
Is it possible to cut a larger resin top to fit a non-square area? Is there another construction material inside the resin top that could cause a problem? And thirdly, what would you recommend cutting it with?
Thanks in advance for your thoughts and replies.
Bodgey Builder is offline   Reply With Quote
Old 08-25-2010, 06:09 AM   #2
I have never seen a flat wall, some are not too bad but never flat. Most tops with built in backsplash have a protrusion on the back for scribing, although it may not be enough. If that is still too far out, lots of caulk is the next solution. A top with no backsplash can be scribed to fit most any wall. Depending on the material, a router, belt sander, power planer, etc., can be used.
Old 08-25-2010, 03:29 PM   #3
Depending on the size of the gap and the look you're trying to achieve you could use a moulding to both cover the gap and enhance the look. I would recommend a ceramic tile or natural stone quarter round or bull nose. Both come in an array of shapes and colors. Hope this will stir your creatitivity.
marmendariz is offline   Reply With Quote
Old 08-28-2010, 12:13 AM   #4
Thanks for your answers, guys. The bullnose idea just might work and not look too bad.
I didn't illustrate before how bad the gaps were. No matter how the top was positioned, the gap would taper from 0 at one corner and grow to 15mm at the further corner sharing that edge. And this is true of all three sides facing a wall.
I'll check my local suppliers and see what I can find.
Vanity - too tight a fit? 9728 Building & Construction 7 12-14-2009 08:42 AM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 01:12 PM
Vanity Tight Fit Chemist1961 Remodeling 2 01-10-2009 02:30 PM
Machining Marble SideSplash for Vanity jombres Remodeling 4 12-03-2006 05:38 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
