Modifying Existing Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2009, 02:20 PM   #1
Modifying existing pipe
Hi
I have 2 problems similar in nature.
1) I need to install a Y fitting in a already existing 3 inch vertical pipe that runs from the basement floor up into the first floor.
If I cut this pipe, how can I insert the Y fitting, since I cannot move the upper part or lower part of the pipe?
2) I need to install a Y fitting into an already existing 3 inch horizontal pipe underneath the basement floor. If I cut this pipe, ow can I insert the Y fitting into the pipe, since I cannot move the left and right parts of the pipe?
All are plastic pipes.
Thanks.
altadata is offline   Reply With Quote
Old 02-10-2009, 04:08 PM   #2
Can you loosen the upper section of the vertical pipe and pivot it sideways?
Chemist1961 is offline   Reply With Quote
Old 02-10-2009, 11:48 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,648
Ayuh,...
If you can't manage enough Wiggle room for the plastic install,...
Use Fernco rubber couplings...
Bondo is online now   Reply With Quote
Old 02-11-2009, 11:09 AM   #4
Go with No-hub couplings and hubless fittings. Cut out the section of pipe 1/4" longer than the fitting, put a coupling on each of the pipe ends (don't forget to also slide the metal shield on the pipe first) and pull back the rubber over itself. Slip the fitting in and pull the rubber back and over the fitting. Slide the shield over the rubber and tighten up the clamps. In many areas, No-hub couplings are allowed under concrete or underground, and Fernco are not.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 09:50 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 09:35 AM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
