Moaning In Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2011, 07:21 PM   #1
moaning in pipes
HELP!! When we turn on any faucet in the house there is a moaning sound when the faucet is running @low stream or when turned off.... sometimes just a short moan other times lasts several seconds ~ hot or cold!
This started several weeks ago. We replaced the pressure reducing valve; pressure holds steady @50psi. This helped for a couple of weeks and it's started again. The noise seems to be in the area of the PRV. About 5 years ago, we had an expansion tank installed in the same area ~ (this checks good; holding air @40psi). Between these PRV and the exp. tank, we have a whole house filter that was installed several months ago.
We turned off the main inlet and opened all the faucets ~ drained completely ~ to let out any air build-up. Didn't help.
THANX for any help or suggestions!
carrollpro is offline   Reply With Quote
Old 02-18-2011, 08:13 PM   #2
Rewards Points: 212
I lived in a houe with the same problem and am eager to hear from the plumbers what th cause is
bluebird5 is offline   Reply With Quote
Old 02-18-2011, 08:15 PM   #3
firehawkmph's Avatar
Rewards Points: 1,800
Carrol,
One of your faucets or one of the other devices probably has a bad washer. When I was on the fire dep't, we would occasionally get a call like yours. Usually was the faucet on the laundry tub in the basement. Sounds crazy doesn't it? I just had a similar situation with my kitchen faucet. When you turned it on, you would here a pulsing noise like a mini- waterhammer sound. After three weeks, it turned out to be a pinhole leak in the hose that went to the sprayer. Try turning the shutoffs on your faucets all off then see if the sound goes away. If it does, turn them back on one at a time to isolate the culprit. Let us know what you find.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 12:20 PM
Pipes Moaning Billydee Plumbing 1 12-28-2009 01:30 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 09:15 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 10:03 PM
