Is This A Mixing Valve Problem? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-30-2010, 11:28 PM   #1
Rewards Points: 212
Is this a mixing valve problem?
I am NOT a plumber nor do I pretend to be one. So here it goes...my son was taking a shower in his bathroom and he called me in to say that when he puts the hot on there's barely any water but when you add more cold the pressure is full throttle coming out of the shower head.
I checked this myself today and he's right there was very little hot water coming out of the shower head even when it was all the way over to hot, but the more cold you added the higher the water pressure came out of the shower head.
Now, I remember seeing something like this on TV and I "believe" I remember seeing that they said it was something called a mixing valve is bad and needs replacement.
If this is true, should I just replace the whole shower fixture or just the mixing valve? The fixture is probably about 10-11 years old and its those contractor grand pieces of crap. Or is there something else I should look at doing?
imola ghost is offline   Reply With Quote
Old 05-31-2010, 07:56 AM   #2
Rewards Points: 1,548
Most likely some sediment or a small pebble got caught in the hot side of the mixing valve.
You will need to disassemble the mixing valve and try to clean it out. Also the hot shower faucet if that is separate.
Does the hot water faucet in the nearby sink work OK?
Old 05-31-2010, 10:52 AM   #3
Rewards Points: 212
1) OK
2) I'll look at it even though I've never taken one apart but I'm pretty good with things like this.
3) Yes, perfectly fine with plenty of pressure.
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
New member, mixing valve question. morrow Plumbing 4 02-25-2010 08:55 PM
Furnace Gas Valve Problem? heavenboundbike HVAC 4 02-02-2010 10:00 AM
shower mixing valve mdm101 Plumbing 2 12-12-2009 08:58 AM
Heil problem with gas valve Frank4711 HVAC 1 12-14-2007 10:03 PM
