Old 04-10-2012, 07:51 PM   #1
Unhappy
Mixer Valve Leak
I have a mixer valve that is leaking where the pvc pipe joins in to the steel threaded nut of the mixer valve. When I try to tighten that connection, I loosen the others. Is there any easy way to tighten just one of the connections or to back that connection out so we can put more pipe tape on the threads and tighten back up. Help! Broke home repair lady
willie1617 is offline   Reply With Quote
Old 04-10-2012, 07:55 PM   #2
Mixer Valve Leak
Some pictures would sure help.
Should be CPVC, copper or Pex not PVC for supply lines.
Old 04-10-2012, 09:32 PM   #3
Mixer Valve Leak
a picture is worth a 1000 words..or in this case worth a fix....
ben's plumbing is online now   Reply With Quote
Mixer valve to transfer valve installation CarlV Plumbing 0 09-13-2011 12:28 PM
cost - leak on main water line and changing valve sandrashand Plumbing 13 01-15-2011 08:56 AM
shower head and mixer valve on opposite walls scramble Plumbing 0 02-28-2010 01:50 PM
Misbehaving shower mixer valve ranagnos Plumbing 6 03-03-2008 08:24 PM
