Mixer Valve Has No Shut Off Is This An Option? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-10-2012, 06:04 AM   #1
Mixer valve has no shut off is this an option?
I do not have a valve shut off on this mixing valve that I can see, thereís a constant leak that has been dripping for 5months. I believe Itís just a busted washer I need to replace. At my other house there is a screw I turn and it shuts off the water to the valve so I can take out all the pieces. Please tell me how there is some way I can shut this water off from the mixing valve or do I even have to for replacing the washer? I cannot get access to the main valve. It's locked up.
If I take out the spindle can I then put it back in with the water coming out? I'm thinking maybe I can force the pressure out the tub spout?
Mixer valve has no shut off is this an option?-1.jpg   Mixer valve has no shut off is this an option?-2.jpg   Mixer valve has no shut off is this an option?-3.jpg
mrich617 is offline   Reply With Quote
Old 11-10-2012, 06:25 AM   #2
DIY staff
Rewards Points: 7,174
Don't try to fix that with the water on-----you will not succeed and turn a simple cartridge repair into a lifetime memory.
Get the water turned off----or live with the drip-----I could tell you a couple of very funny stories about situations like yours where the unit owner didn't want the association to know that they were trying to do work without hiring the plumber----
plumberinlaw (11-10-2012)
Old 11-10-2012, 08:41 AM   #3
Rewards Points: 352
If you try to repair that without turning the water off first make sure you have somebody with a camera taking pictures. Post here when done and let us know how it worked out.
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
oh'mike (11-10-2012)
Can you solder within an inch of a closed shut off valve? amodoko Plumbing 17 08-16-2012 12:29 AM
Mixer valve to transfer valve installation CarlV Plumbing 0 09-13-2011 11:28 AM
Sizing a dual shut off valve for a water line to fridge ericman Plumbing 10 08-19-2011 09:47 PM
Toilet Water Shut Off Valve anelson Plumbing 1 07-11-2011 09:42 AM
