Mixer Valve Bypassing? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-15-2011, 12:31 PM   #1
Mixer valve bypassing?
I have a new water heater, and some times I get very hot water, mostly though I get luke warm water. I can only assume that the mixer valve is letting cold water past. The Tank is set to 125*. From the attached diagram, does anyone have any thoughts? The mixer valve does not look very fun to remove, and replace.
Thanks.
cc
carboncopy is offline   Reply With Quote
Old 11-15-2011, 03:03 PM   #2
Rewards Points: 87
Is that some kind of a recirculating apparatus you got on top of that heater to keep hot water circulating all the time so you have instant warm water?
I have not seen a set up like this on a water heater install before. What I have seen is one installed on the line under your bathroom sink.
Tom
TGMcCallie is offline   Reply With Quote
Old 11-15-2011, 03:28 PM   #3
Sorry that is actually to in-floor heating for the lower living room.
Update: I shut of the valves to the in-floor heating yesterday so this in not a factor. You can see the one valve just before the pump, and the other on the upper line at the far left. In the morning I had a cool shower for the first 5 minutes, then it began to warm to a luke warm temperature.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Mixer valve to transfer valve installation CarlV Plumbing 0 09-13-2011 11:28 AM
