Mission Coupling - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2012, 08:09 AM   #1
Mission Coupling
Does UPC code say anything about couplings used on the main drain? I want to use a mission coupling for a 3" PVC to 3" copper transition on the main drain where it exits the wall. I would of course have everything properly supported so as not to put any undue stress or strain on the coupling/joint.
kevsprojects is offline   Reply With Quote
Old 03-18-2012, 09:33 AM   #2
Rewards Points: 2,240
As far as I know it's OK.
Use a "mission-band" with a stainless-steel wrap.
rossfingal
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
jaydevries (03-18-2012)
Old 03-18-2012, 05:10 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 996
Under the ipc which I understand is close to the upc that coupling cannot be use in a horizontal application. Except at the lateral. Some inspectors will let it fly if the 3 is inserted at least 2 inches into receiving piper example going from 3 to 4.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-19-2012, 05:38 AM   #4
Can you reference the page or section in the IPC? I actually meant IPC in my original post.
Old 03-19-2012, 08:25 AM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 996
Not sure you would find it in the book, this was discussed at continuing education class, the code book make very little reference to repairs, most are left to the field inspectors judgment, what may be ok to one inspector may not be for another, in this case we covered this coupling in a state continuing education class. So we y got the information from a code compliance instructor. May be ok in other states under the ipc.
Old 03-19-2012, 07:56 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Do you have a picture of pipe youre trying to repair?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 03-19-2012, 08:30 PM   #7
Rewards Points: 636
so if this is true how do you connect no hub cast in a commercial setting or sometimes residential
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-19-2012, 09:35 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 912
There can be no argument if it's shielded
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
jaydevries (03-19-2012), plummen (03-20-2012)
Old 03-19-2012, 10:03 PM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 996
4 to 3 cast iron 4x3 reducer no hub with no hub coupling / pvc to cast same but with no hub adapters and no hub couplings 3 inch copper to cast or pvc Hercules couplings with transition adapters. All solid unions no rubber spacing.
Old 03-20-2012, 03:41 PM   #10
Owner
LateralConcepts's Avatar
My question would be: Why is the building drain or building sewer only 3"?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 03-20-2012, 06:34 PM   #11
plummen's Avatar
Im guessing it probably jumps to 4" outside the wall
Old 03-25-2012, 08:09 AM   #12
No pics yet but my drain is 3 inch copper and transitions to 4 inch pvc just beyond the stem wall on the outside. The ultimate way to do it I guess would be to dig down to the 4 inch and run pvc back into the house fro there.
reuse rubber PVC coupling? csab_ Plumbing 21 01-21-2012 10:23 PM
Specialty bolt - Lag bolt with attached coupling nut? 5thumbs Building & Construction 6 08-22-2011 01:08 PM
Using a rubber coupling instead of PVC coupling sukhenkoi Plumbing 2 04-05-2011 06:53 AM
Fernco coupling inside wall bryan1282 Plumbing 1 03-24-2011 10:59 PM
How do you remove plastic coupling nut and washer from braided metal connector? tony__s Plumbing 3 05-15-2008 10:15 PM
