Minute Gas Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-12-2006, 06:41 AM   #1
Rewards Points: 528
Minute Gas leak
Hello,
I have a small gas leak either coming from my Gas dryer or my hot water heater. I tried locating it by using soap suds to no avail. I suspect its coming from the piping thats behind the dryer and its not accessable for testing as I have to disconnect it to pull the dryer away from the wall. So I turned off its supply valve to see if the leak stops while still letting the hot water heater operate from the main shutoff. My questions are:
Is there a product thats better then soap suds for detecting leaks?
What about the heater itself? Could it be that there is too much delay between introduction of gas at the burner and ignition.
Looking for ideas.
rjordan392 is offline   Reply With Quote
Old 11-12-2006, 06:55 AM   #2
World famous jerk.
I generally use the leak detector soap that they sell at refrigeration supply houses, but it's basically the same as what you're using. It has fluorescent dye in the soap so you can see the bubbles a little better. The gas company most often will come out for free with their electronic "sniffer" and find the leak in a heartbeat for you. Trouble is, they can turn off your gas service, depending on what they find while they're there. You can buy a "sniffer" too, but they're quite expensive.
mdshunk is offline   Reply With Quote
Old 11-12-2006, 08:08 AM   #3
Even a small leak is not a good thing. I would suggest disconnecting the dryer and purchase a plug and then test the piping while plugged. This will let you know if it is the dryer piping itself. Use the soap solution on ALL connections and the valves. Make sure to check all around the controls on the water heater also. If it was a delay between gas flow and ignition, you should hear a POP when it lights. You MAY be able to rent a sniffer but I haven't seen them where I rent seldom used tools. Good luck.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-12-2006, 10:59 AM   #4
Rewards Points: 528
Thanks,
I only noticed the smell about 3 to 4 times a week. With the dryer supply shut down, I will give it a couple days so as to isolate which is at fault.
EPDM Roof Repairing Protrusion Leak Basic_Homeowner Roofing/Siding 3 06-06-2007 04:45 PM
Fixing a threaded leak without disassembly love4god Plumbing 6 05-21-2007 07:57 PM
Central heat and air unit leak ? bdalekid HVAC 1 03-21-2007 07:31 AM
pipe leak & sheetrock damage santogr General DIY Discussions 2 03-04-2007 01:44 PM
Hot water heater leak? chrisintroy Plumbing 3 02-27-2006 09:13 AM
