Minimum Height Of Tub & Shower Drains? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-26-2012, 11:07 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 802
Minimum Height of Tub & Shower Drains?
On my upstairs shower and bath, both p-traps will be draining into a 2" horz line....which is only going to be about 12" below the drain of the respective device....This is about as far down as I can go until I transition down another wall into my main sewer.
So....I assume that there is no min height? I hope there isn't.
I do know that the vent for each respective drain has to be at least 6" aove the highest drain connection (that part is not an issue)
ddawg16 is online now   Reply With Quote
Old 10-26-2012, 09:19 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
No minimum. Maximum tailpiece under UPC is 24"
Journeyman Plumber
main panel minimum height above floor amakarevic Electrical 5 08-13-2012 05:54 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 09:03 PM
shower curb height chulett Plumbing 8 12-10-2011 02:18 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
minimum window height mt232 Building & Construction 7 03-24-2007 02:10 AM
