Minimum Fall - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-28-2006, 01:45 PM   #1
Question
Minimum Fall
I am running (burying) 4" PVC from the downspout away from the house. What is the minimum fall I should have in the pipes. Thanks.
Bill46 is offline   Reply With Quote
Old 08-28-2006, 05:27 PM   #2
Home Improvement Guy
ron schenker's Avatar
What will the rainwater be dumping into at the end of the pipe if it's underground? Is there just one downpipe?
As for the slope of the pvc, I would say 1/4" for every one foot.
ron schenker is offline   Reply With Quote
Old 08-28-2006, 06:22 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Depends on what code you use, hear as long as there is no backgrade it can be flat, but slope is always best, 1/8 for rain drains.
Ron The Plumber is offline   Reply With Quote
Old 08-29-2006, 09:00 AM   #4
Ron: Thanks. The pipe will be draining onto the front lawn which slopes pretty steeply away from the house.
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 12:32 AM
Holly bushes - when to trim BrianL Landscaping & Lawn Care 4 04-24-2007 02:40 PM
minimum window height mt232 Building & Construction 7 03-24-2007 01:10 AM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-05-2005 11:03 PM
minimum impact switchbox sherlock Electrical 5 10-20-2005 06:34 PM
