Minimum Drain Size For Tub/shower And For Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-05-2012, 12:55 AM   #1
Rewards Points: 199
minimum drain size for tub/shower and for sink
If a sink or a tub/shower has a 1.5" tailpiece, is there any advantage to having it drain into a 2" pipe rather than just keeping the drain pipe the same 1.5" size as the tailpiece ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 10-05-2012, 01:12 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 450
Thanks,
Arky
No big advantage but it won't hurt either.
My state does not allow 1.5" pipe under a slab, so all our basement tubs and lavs are piped 2".
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (10-05-2012), oh'mike (10-05-2012)
Old 10-05-2012, 08:17 AM   #3
Rewards Points: 3,130
Do you know the basis for this rule? Just curious.
Old 10-05-2012, 11:10 AM   #4
Plumber
Rewards Points: 450
No, not really. I started plumbing here in the mid 80's and that rule was in place then too. I have been told that since 1.5" is used mostly on lavs and tubs, it is upsized to avoid blockage as it is not accessible (under slab) to repair. But thats not an official response. The rule holds for venting under slab too.
Here's another one- regardless of the fixture load on the building drain, I must stub 4" out of the building with a 4" clean out.
You can tell when a Washington plumber crosses the border for work- they sometimes forget these rules.
We work off UPC and are in the process of adopting IPC (Idaho Plumbing Code) It too is adopted from UPC. but has several venting modifications- or so I'm told. I haven't read it yet
