Mini Split Condensate Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2013, 12:02 PM   #1
Hi, Can I'm planning to install a minisplit in my basement and I don't want to have a condensate pump on it, so my question, can the Condensate Drain hose go to my utility sink?
amb1s1 is offline   Reply With Quote
Old 03-26-2013, 06:04 PM   #2
Rewards Points: 1,866
Yes it can
Old 03-27-2013, 06:20 AM   #3
Rewards Points: 1,216
Can you run it outside with the line set? Thats what I did.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 03-27-2013, 09:15 AM   #4
I can do that, but I will need a condensate pump. I don't want to use any pump. I'm also installing a tankless water heater, so I would like to be able to use the utility sink drain for that. How should I do this? Just drop the hose on the sink or install a pipe under the utility sink?
Mini split heat pump for us? Cedrus HVAC 5 03-08-2011 09:47 AM
Condensate draining into sink drain fritzycat1 HVAC 0 01-23-2011 01:39 AM
is it ok to drain condensate to a below slab interior perimeter drain? steveel HVAC 2 12-03-2010 05:20 PM
Condensate Drain Pan Leak tbfreeland HVAC 0 09-01-2010 10:34 PM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 09:33 PM
