Min Size For TUB Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2014, 04:40 PM   #1
Min size for TUB drain
Hi all. I am changing around my bathroom and want to flip the way the tub is. Just wondering what the minimum size for the drain I can get away with. I'm going to have to go through 1 joist and want to keep the hole as small as I can.
ahrens is offline   Reply With Quote
Old 05-10-2014, 04:44 PM   #2
Rewards Points: 13,468
Showers need a 2" drain.
plummen (05-10-2014)
Old 05-10-2014, 05:01 PM   #3
Rewards Points: 1,874
Depends on the state your reside in and what plumbing code they follow. It also is sized by the amount of shower heads and body showers hand held etc.
Old 05-10-2014, 06:09 PM   #4
DIY staff
Rewards Points: 7,174
Tub drain or shower drain---please clarify--
Old 05-10-2014, 06:53 PM   #5
It would be a tub
Old 05-10-2014, 07:05 PM   #6
Well that's confusing.
First line of your post is minimum size of a shower drain.
Old 05-10-2014, 07:12 PM   #7
Sorry about that, I just call it the shower but it's a tub with a spout and then the shower head up top. Again sorry about the confusion
Old 05-10-2014, 07:14 PM   #8
Rewards Points: 582
most tubs require a 1 1/2 drain.....
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 05-10-2014, 07:59 PM   #9
DIY staff
Fixed the title for you---
Screw size for bathtub drain Ultrarunner2017 Plumbing 4 03-26-2014 06:56 PM
minimum drain size for tub/shower and for sink Arky217 Plumbing 3 10-05-2012 10:10 AM
Adding drain line in basement floor - size and trap? theedudenator Plumbing 0 07-11-2011 09:22 PM
please help with clawfoot tub drain - obselete tube size? wombosi Plumbing 1 01-27-2009 02:26 PM
Old Clawfoot Tub Drain missing nut - can't find size! wombosi Plumbing 0 01-26-2009 04:48 PM
