Metric Compression Fittings ??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-27-2007, 10:48 PM   #1
Question
Metric compression fittings ???
I bought two faucets on ebay and they both have metric compression fittings. they are almost the same size of 3/8" compression what and where do I get some adaptors or fittings that I can convert to hook up to my water lines?
rutalkn is offline   Reply With Quote
Old 11-27-2007, 10:56 PM   #2
ICF Construction
Ahh you need 10mm couplers. I have run into this, the only luck I have ever had was to contact the manufacturer they all have reps here in the US and can get you a conversion kit for a nominal fee.
Chris
Chris Johnson is offline   Reply With Quote
Old 11-27-2007, 11:18 PM   #3
Thanks, hopefully the seller replies eventually, the box doesn't have a name of a manufacturer on it but any euro company mabe would be the same.?.?
Old 11-27-2007, 11:43 PM   #4
ICF Construction
I tried to get conversion parts at the local wholesaler and we just couldn't get it to work, called the manufacturer and 3 days later everything was working...find out the manufacturer
Chris
ice maker line in wall and fittings cshousley Plumbing 5 10-01-2007 05:01 PM
PEX fittings simonb Plumbing 1 09-18-2007 03:11 PM
iron pipe fittings farrington135 Plumbing 1 07-13-2007 09:16 PM
iron pipe fittings Talman48 Plumbing 2 01-10-2007 06:11 AM
installing compression valves markymark Plumbing 2 08-11-2005 11:03 PM
