Method For Running A Water Line For An Icemaker - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-29-2012, 07:01 AM   #16
Rewards Points: 1,216
Install a tee in the copper section with the proper valves, 1/4 inch copper to the ice maker hookup, leave some loops of copper(like a slinky) behind the refrigerator so you can pull it out for cleaning and service, put the end of the copper in a bucket have someone open the water valve under the sink to make sure there's no dirt in the line, then hook the line up to the ice maker water line, start the ice maker and throw out the first bin of ice, use the second bin full. Do Not Use Saddle Valve and Plastic.
COLDIRON is offline   Reply With Quote
Old 02-29-2012, 07:39 PM   #17
Rewards Points: 582
great directions
The Following User Says Thank You to ben's plumbing For This Useful Post:
COLDIRON (03-01-2012)
Old 02-29-2012, 08:19 PM   #18
Rewards Points: 1,574
Big box or other supply place should have something like this:
to connect sink and ice maker line to your under sink water supply.
bob22 is offline   Reply With Quote
Old 02-29-2012, 08:31 PM   #19
Homerepairguy's Avatar
Rewards Points: 990
Originally Posted by ben's plumbing View Post
great directions
+1
And to clarify, the diameter of the "slinky" should be about 3 feet, not a 6 inch diameter "slinky".
HRG
Homerepairguy is offline   Reply With Quote
The Following 2 Users Say Thank You to Homerepairguy For This Useful Post:
ben's plumbing (02-29-2012), COLDIRON (03-01-2012)
Tags
fridge , ice , maker
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
Re-routing main water line (perpendicular to joists) near ductwork and gas line? jjcatal Plumbing 1 03-29-2011 11:18 PM
Hook up water Line to Icemaker Delta69 Plumbing 1 01-12-2010 06:18 PM
My water line install to icemaker jrowny Plumbing 3 01-24-2009 03:32 PM
