Method For Running A Water Line For An Icemaker - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2012, 09:40 PM   #1
Method for running a water line for an icemaker
Hey all!
I want to install the ice maker kit in our freezer. Problem is I have no plumbing going to the refrigerator. The run seems easy enough, about 18 feet from the sink to the top of the refrigerator. The ice maker hookup is at the top of the fridge.
The question I have is how to go about running it. Part of the way I will be able to run it under my built in cabinets. I know it won't be disturbed and possibly leak under here. When I get to my stove I have no place to keep it safe. Should I route it into the wall from here and bring it back out when it gets to the wall behind the fridge? I read somewhere online about routing it through the ceiling which seems like a very bad idea.
Also, what type of tube should I use?
Michaelpro is offline   Reply With Quote
Old 02-28-2012, 09:42 PM   #2
Rewards Points: 582
Originally Posted by Michaelpro View Post
Hey all!
ok back up...is this house on a slab..no basement??? most ice makers hook up at bottom left of frig
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (02-29-2012)
Old 02-28-2012, 09:44 PM   #3
Sorry. I assume everyone is on a slab which isn't the case haha.
This ice maker is an add on kit. I assume it will hook up at the top where the connections are made, but haven't actually seen it yet.
Old 02-28-2012, 09:51 PM   #4
Rewards Points: 582
get the kit and see what is required to install....as far as tubing I use copper but that its always comming from a basement...you could use plastic kits but as you are saying need to protect line under cabinets ok behind stove should not be a big deal either not like its going to get disturbed there ..maybe slip into another pipe in the stove area....
Old 02-28-2012, 09:51 PM   #5
I forgot to post the little image I made
The Following User Says Thank You to Michaelpro For This Useful Post:
ben's plumbing (02-28-2012)
Old 02-28-2012, 09:55 PM   #6
Sorry I mistyped there. I am not afraid it will get disturbed under the cabinets.
Actually the plastic tubing through some PVC wouldn't be a bad idea. It would have great protection just in case something bad happened haha.
Old 02-28-2012, 09:59 PM   #7
Rewards Points: 582
you got the idea...I thiink you will do just fine...let us know how you make out,,ben
Old 02-28-2012, 10:30 PM   #8
It seems most kits come with self piercing saddle valves for water installation. I have flexible aluminum tubing running to my kitchen sink.
Old 02-28-2012, 11:04 PM   #9
Rewards Points: 13,276
Do not use a piercing valve even if that's what it comes with. Tap into the main water line under the house and add a ball valve instead. With a piercing valve there's far to much chance of it leaking and plugging up.
Run the line under the house not through the cabinets.
The very best way is to add a shut off box right in the wall behind the ref.
http://images.search.yahoo.com/image...mb=cpCLpHoH11V
Old 02-28-2012, 11:09 PM   #10
I really have no way to access the main water line without a lot of heartache. This silly slab foundation and all.
Old 02-28-2012, 11:35 PM   #11
Just a DIY guy
But you must have a valve under the sink. I'm no plumber, but I'd bet you could hook up a tee of some kind before or after the valve, and run your line out of the tee.
The one thing I do know is that the saddle valves are no longer allowed by code, 'cause they tend to leak.
M3 Pete is offline   Reply With Quote
Old 02-28-2012, 11:39 PM   #12
Rewards Points: 582
as mentioned I really would not use a saddle valve. your code my permit it? just not the best installation...if its not a code violation and you have to use it ...ok.....
Old 02-29-2012, 12:18 AM   #13
I don't want to use one either. It seems like a bad idea as well haha. I think something like this would work
What would I get from there to make the connection to the 1/4 inch ice maker line? Installing a shut off valve behind the fridge seems unnecessary as there will be a valve under the sink.
Old 02-29-2012, 12:24 AM   #14
Post a picture of under the sink.
Not the right fitting shown in that picture.
Old 02-29-2012, 12:33 AM   #15
I have 3/8 inch connectors.
Tags
fridge , ice , maker
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
Re-routing main water line (perpendicular to joists) near ductwork and gas line? jjcatal Plumbing 1 03-29-2011 11:18 PM
Hook up water Line to Icemaker Delta69 Plumbing 1 01-12-2010 06:18 PM
My water line install to icemaker jrowny Plumbing 3 01-24-2009 03:32 PM
