Metal Closet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-21-2008, 06:09 PM   #1
Metal Closet Flange
I have a bathroom in my basement. I have a toilet and no sink. I want to add a sink by adding a drain to drain into the toilet drain. But the closet flange is metal. What is the best way to get this removed so i can replace it with a plastic one to tie in my sink drain?
My floor is 3 in concrete so i dont have access to it from the bottom.
Any help would be appreciated.
Thank
darman16 is offline   Reply With Quote
Old 03-21-2008, 06:34 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You will need to open the floor and tie into the mainline, then run new line to sink location, there is no other way to do this.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-21-2008, 06:57 PM   #3
what would be the best way?
its about 3 inch iron pipe. Would i just cut it and add a pvc T joint for the sink drain?
Thank
Old 03-21-2008, 06:57 PM   #4
Thank
Old 03-21-2008, 06:59 PM   #5
Journeyman Plumber
Once you find the line then yes you will cut in a wye fitting to connect in your sink drain.
Is this sink going to be on the same wall as the toilet sits on? If so, how far away will it be from the toilet?
Old 03-21-2008, 07:18 PM   #6
its going to be on the opposite wall
about 3 feet away from the toilet.
Old 03-21-2008, 07:28 PM   #7
Journeyman Plumber
Then you need to go into the floor.
Old 03-22-2008, 03:14 PM   #8
Hi,
I am through the floor but the drain pipe is clay/ceramic. Im not sure how to tie into this. Could you please help.
Old 03-22-2008, 03:43 PM   #9
Journeyman Plumber
Get rubber fernco coupling and snap the line to put the fitting in.
Old 03-23-2008, 12:58 AM   #10
I used one of those, The terracotta pipe was a pain to snap evenly though.
thanks again
Old 03-23-2008, 10:52 PM   #11
Also,
Would it be ok to use plastic pipe to run the water line?
Or should I stick to coper pipe?
Originally Posted by darman16 View Post
thanks again
Old 03-23-2008, 10:53 PM   #12
Journeyman Plumber
Copper or pex is preferred.
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Closet flange unsupported Richo Plumbing 6 01-02-2008 03:44 PM
closet flange wax ring problem elkmo Plumbing 2 01-14-2006 03:30 PM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 05:42 PM
