-   -   Metal Closet Flange (http://www.diychatroom.com/f7/metal-closet-flange-18801/)
darman16 03-21-2008 05:09 PM
Metal Closet Flange
I have a bathroom in my basement. I have a toilet and no sink. I want to add a sink by adding a drain to drain into the toilet drain. But the closet flange is metal. What is the best way to get this removed so i can replace it with a plastic one to tie in my sink drain?
My floor is 3 in concrete so i dont have access to it from the bottom.
Any help would be appreciated.
Thank
Ron The Plumber 03-21-2008 05:34 PM
You will need to open the floor and tie into the mainline, then run new line to sink location, there is no other way to do this.
darman16 03-21-2008 05:57 PM
what would be the best way?
its about 3 inch iron pipe. Would i just cut it and add a pvc T joint for the sink drain?
Thank
Thank
Ron The Plumber 03-21-2008 05:59 PM
Once you find the line then yes you will cut in a wye fitting to connect in your sink drain.
Is this sink going to be on the same wall as the toilet sits on? If so, how far away will it be from the toilet?
darman16 03-21-2008 06:18 PM
its going to be on the opposite wall
about 3 feet away from the toilet.
Ron The Plumber 03-21-2008 06:28 PM
Then you need to go into the floor.
darman16 03-22-2008 02:14 PM
Hi,
I am through the floor but the drain pipe is clay/ceramic. Im not sure how to tie into this. Could you please help.
Ron The Plumber 03-22-2008 02:43 PM
Get rubber fernco coupling and snap the line to put the fitting in.
darman16 03-22-2008 11:58 PM
I used one of those, The terracotta pipe was a pain to snap evenly though.
thanks again
darman16 03-23-2008 09:52 PM
Also,
Would it be ok to use plastic pipe to run the water line?
Or should I stick to coper pipe?
Originally Posted by darman16 (Post 110025)
thanks again
Ron The Plumber 03-23-2008 09:53 PM
Copper or pex is preferred.
