Messy Gate Valve Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2010, 10:40 PM   #1
Messy Gate Valve replacement
Hi,
This is my first post and i am thrilled to find a DIY community online. i have a stuck gate valve and am planning to replace it with a ball type valve.
Since i have copper pipes i tried to mark the locations around the valve to cut. The problem is that the upper end of the valve is very close to a L-shaped joint. I have just about 1/4 inch clearance between the joint and the valve.
How do i cut the pipe and if i manage to somehow cut the pipe, i wont have enough pipe to attache the new valve.
Please advise. Thanks a million in advance.
Regards,
Tepe
toxicprison is offline   Reply With Quote
Old 11-26-2010, 11:40 PM   #2
I have uploaded a picture to help explain the situation better. Thanks.
Old 11-27-2010, 05:21 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Don't cut it off. Drain the water, cut off the lower leg, unsolder the upper leg. Solder a new ball valve to the upper leg. Make up the lower leg with a short piece of pipe and a repair coupling.
Coastal South Carolina
The Following 3 Users Say Thank You to rjniles For This Useful Post:
oh'mike (01-19-2011), Thurman (11-27-2010), toxicprison (11-27-2010)
Gate valve won't open (water heater) Greyhounder Plumbing 8 07-25-2015 05:29 PM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Need to ID Gate Valve (Please Help) MikeGV Plumbing 3 10-04-2010 12:02 PM
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 01:02 AM
Toilet valve replacement? steve771 Plumbing 18 07-10-2007 11:50 AM
