Old 01-30-2010, 11:08 AM   #1
CC1
Meridian Plumbing Supplies
Hope you can help....I have a 4-year old stall shower in a finished basement that I rarely use, with a shower faucet built by Meridian, a company's that's NO longer in business. I called a plumber because the shower was leaking. He recommended I replace the cylinder unit made of plastic that's attached to the hot/cold volume control lever. The cover plate has two holes above the hot/cold volume control lever for screws, which attach to an interior mount.
I found out that Meridian was out of business when I tried to replace the shower faucet unit at the home store where I originally purchased it.
I DON'T want to tear-up the stall or the plumbing in the wall to replace the entire shower faucet. I'd like, instead, to replace the plastic cartridge unit. The home store where I originally purchased the faucet set told me it would be impossible to find a comparable cartridge, but it seems to me, from looking at the cartridge unit, that it's probably a stock item that's used by multiple manufacturers. I haven't called the plumber back to give him the news about Meridian being out of business.
My question....Is there a large plumbing outlet supplier out there on in the www that may have Meridian parts, or can I count on the plumber to be able to just repalce the plastic cartridge attached to the current Meridian hot/cold volume lever?
CC1 is offline   Reply With Quote
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
How to find plumbing distributors for plumbing invention? Timster Plumbing 7 05-20-2009 02:53 AM
Connecting new plumbing into existing plumbing Just do it guy Plumbing 2 02-18-2008 10:36 PM
