Media For A Macclean Backwash Filter - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-13-2012, 12:31 PM   #1
media for a macclean backwash filter
I have recently bought a home that has a Macclean NMB1001 backwash filter system. I was taking it a part today to clean it and notice that there was only 3 inches of gravel at the bottom of the tank. I looked through the service manual to see if this was right but all signs indicate that there should be some kind of media with this filter. The previous home owner left bags of play sand but no word what it was for and why it was left. Can this sand be used as the media. Thanks for any advice.
Tahiles is offline   Reply With Quote
Old 04-13-2012, 01:31 PM   #2
Water Treatment
Rewards Points: 848
Kind of sounds like a Neutralizer filter or to correct the ph of the water.
Over time the calcite and or mag oxide mix will be eaten away by the acidic water.
Play sand? or fine calcite?
Akpsdvan is online now   Reply With Quote
Old 04-13-2012, 05:38 PM   #3
Thanks for writing in. It is play sand but I don't believe its usefull
To me. So a fine calcite is better?
Old 04-13-2012, 10:50 PM   #4
Water Treatment
Rewards Points: 848
Either form of calcite will work, fine or a more course form.
Depending on the size of the media tank as to how much calcite will be needed.
10x47 tank =1.0 cubic foot or 100 lbs
10x54 tank =1.5 cubic feet or 150 lbs
I would hold that play sand as you call it until you get some calcite to put next to.. just in case it is the fine calcite ...
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 01:05 AM
Inground pool and filter...HELP! Blpavlovich Building & Construction 2 06-09-2011 06:49 PM
DIY water filter and backwash system grazzze Plumbing 0 05-30-2011 09:29 AM
Adapting round duct to square media filter? lyonkster HVAC 4 04-16-2011 02:42 PM
EAC or Media Filter? BlueBSH HVAC 11 05-02-2010 07:27 PM
