Old 10-03-2011, 11:04 AM   #1
medallist water softener
I have a Culligan Medallist Water softener and there appeared a code E1 (motor will not stop turning) on the screen. Also it was regenerating (water was flowing into it when it was not supposed to be doing this) nonstop. What should I look for or do?
terry12 is offline   Reply With Quote
Old 10-03-2011, 12:04 PM   #2
Water Treatment
Error code "E1" occurs when the circuit board detects changes in the motor
program switch when the motor is not supposed to be turning. The phone icon and "E1" will be lit in the display.
Could be some thing on the board , or it could be the micro switch on the white cam..
Any chance of a photo as to the valve that Culligan used for your unit?
Akpsdvan is offline   Reply With Quote
Water Softener Drainage Problem hodge23 Plumbing 3 09-26-2011 05:40 PM
What to put under water softener? wiz561 Plumbing 4 12-11-2010 09:37 AM
orange water from softener joemontana16 Plumbing 5 11-23-2010 07:34 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
